Question about JVC Car Audio & Video
I need wiring order in the plug itself cause when I got the stereo 2nd hand the plug was missing wires jvc kd-r710
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
SOURCE: JVC Wire Harness
i need to match up color wire to my 1998 honda accord
Posted on Oct 22, 2008
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
motor1258
  • 6674 Answers
SOURCE: I dont know how to wire it to my car stereo wires
Do yourself a favor and run to audio store or even autoparts store & get an adapter plug/harness, cost is a few bucks but well worth it. It plugs into factory harness & you wire your new stereo to it according to diagram with new system.
Posted on May 03, 2009
  • 31 Answers
SOURCE: need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
Posted on Aug 16, 2009
Where can i find new wire harness?
You can obtain a new wire harness from pacparts.com. The part number is JV16-0003. You can also call them at 1-800-421-5080.
Feb 28, 2012 | JVC KD-LH3150 CD Player
Need info on wire color coding for jvc car cd player: JVC KD-G140
Try going to the crutchfield website and look for help installing stereo. they can get you vehicle specific wiring codes for free. Also, almost everey stereo has common color codes for wiring. red- switched batt. +, yellow-constant batt. +, black= ground, blue- power anrenna, etc.
Apr 12, 2010 | JVC KD-G140 Car CD Player
How to install a jvc stereo kd-g230 in a chevy trailblazer 2002
First you need to get a wire harness for the Chevy (check Ebay) then follow the wiring instruction inside the package on how to join the spliced wires togother. After joining the wires togother plug the harness in and stuck the JVC into the recess where the old stereo was and thats it, it should play if not you don`t have a good ground, ground the body to the frame.
Dec 19, 2009 | JVC KD-G230 CD Player
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
Need to find a wiring harness
I would need further information: What most people do not realize is that a wiring harness is not a "one size fits all" thing. There are two harnesses that you may need.
To remove your factory car stereo and install a new aftermarket car stereo there are wiring harnesses for most cars that will plug right in to the wires from your old factory radio.
For that, you will need to buy the correct wiring harness for the year and make of your vehicle. Say, for example: 1987 Toyota.
Then there is a wiring harness for the specific car stereo. You will need the make and model number of the unit itself. Example: JVC model KD-AVX77.
Jul 24, 2009 | Car Audio & Video
Need help with wiring for my jvc kd-dv4202 plug went missing gt new one but the colour on wiring is all wrng
RED is power to ignition,
YELLOW is direct power to battery
BLACK is ground
Orange (optional) is for dimmer switch
Blue goes to amp and subs if you have them
Your even off better going to buy a $5 quick connect at walmart and you just twist the wires together on the quick connect, tape them off, and plug it in.
You can find out which wires of you car are for what at installer.com............When your there, go to wiring and find your car.
Jul 19, 2009 | JVC AM FM CD DET FACE CAR STEREO
JVC Wire Harness
If it fits it will work, If the manufacturer stays the same so does the wiring loom.
Feb 06, 2008 | JVC KD-S5050 CD Player
My JVC KD-SX650
get a good service manual for your car that shows the wiring for the stereo plug. match up the wires to your JVC's wires (solder tie wire-to-wire behind the car's connector)
May 26, 2007 | JVC KD-SX650 CD Player
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
