Question about Toys
Syma 033G won't lift off - Toys
My Syma S107 bottom rotors won't turn. What is the fix?
Probably just the cog on the motor not meshing with the main shaft gear.
Kind regards, Julian
rccontrolfreak.co.uk
Aug 07, 2012 | SYMA Toys industrial New Syma S107 Radio...
S107g won't take off
I may be out of my area of expertise on this one, but it is possible to install the blades backward? That would cause the copter to try to go downward with the normal rotor rotation....just a friendly suggestion.
Dec 30, 2011 | SYMA Toys industrial New Syma S107 Radio...
Syma 107 I no longe get lift, have replaced batteries and have charged from usb cable. still not luck, how long do the li poly batteries last ?
About 5 minutes.
Check if gears are not too tight together.
If it's OK, then one rotor is working slower than the other one, and because of that, S107 can't lift off ground.
Feb 27, 2011 | SYMA Toys industrial New Syma S107 Radio...
My syma s107 will not lift off the ground
Assuming the battery is fully charged, the shaft could be dry, purchase a WD-40 pen, they have a magic marker type tip that dispenses controlled amounts of lube by pressing the tip on a surface to get a drop then use a toothpick to put a small amount on the rotor shaft top and bottom. I did that to mine and the shaft spins a lot smoother. Mine always lifted off with no problem, but it got the gitters and and would drop a few feet now and then. after I oiled the shaft the gitters went away. Give it a try. John.
Dec 05, 2010 | SYMA Toys industrial New Syma S107 Radio...
My Syma S107 will not lift off the ground. what can i do to sort this out?
Had the same problem - the rotors would spin but the helicopter would not take off. Finally tried tightening both screws on the piece just below the Balance bar. I tightened one of the screws about 1/8 turn, and now it works great.
Hi...I bought a syma s018 rc mini helicopter a week ago and it was working great but now, when i fully charge it, it doesn't have enough power to lift off the ground. Is my battery defective? It seems to...
I believe the Syma S018 is the same as my Yiboo UJ417.
Mine never got off the ground out after charging for an hour.
It just skitters along the ground. Must be a bad battery. Returning it if I can.
Nov 13, 2010 | SYMA Toys industrial Syma S018 Air Wolf...
Have a Syma S032 Heli. Is there a guide that shows how the chopter is constructed. My motor works intermediately and before I take apart to try to fix would be nice to have symatic to build back just in...
I just purchased one too and flew it for about 30minutes then the light went off, I put new batteries in and the light still won't come on. please help me :(
Sep 27, 2010 | SYMA Toys industrial Syma S032 Ready to...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
