Question about Directv Televison & Video
How can learn where avr port is on DirecTV box?....After I plugged roku 3500r HDMI into DirecTV DVR box, I have no way to see any roku screens.
I'm trying to hook up roku 3500r streaming stick HDMI to DirecTV DVR box. While looking to see how to use DirecTV remote for roku I found I can program remote to control AV2. *I HAVE NO IDEA WHAT AV1, AV2,OR IR/RF are to set them up on my remote...?
satscoop
  • 59 Answers
SOURCE: hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Posted on Nov 03, 2007
SOURCE: DirecTV RC64R RF Remote control
Actually, you can go into the system settings by choosing "Parental, Fav's & Setup" then choose "system setup" then choose "remote" the IR/RF setup. Change it to IR and follow the instructions. Once I did that my remote worked on my DirecTV DVD HR22-100
Posted on Nov 22, 2008
  • 458 Answers
SOURCE: When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Posted on Oct 25, 2009
kitt98
  • 26 Answers
SOURCE: AV1 AV2 hook up
you should find them by seeing if you can find ports that are colored yellow, red and white
Posted on Apr 01, 2010
jpelectric
  • 3 Answers
SOURCE: DirecTV receiver R15 won't respond to remote RC23
Well, I took the DVR apart and found the power board completely intact, no bulging capacitors. However, the Mother Board had a 220uf/50volt cap that was bulging, so I replaced it. By the way, 'DigiKey' is the only place to go for electronic parts. They'll hook you up! The DVR still wouldn't respond to the remote. Darn it!
So I took both of my DVR's apart and swapped out the Front Board (the one with the Photoamplifier in it) and the DVR would now respond to the remote. OK, so now what do I do. I still have one DVR with a bad Front Board. I started to look on ebay for an old used R15 500 that I could swap parts from...remember, I own my eqipment and the goal is to preserve what I have recorded on the Hard Drive. R15's were going for around $50 -$80. Then I got to thinking. I still had an old non-DVR Direct TV Receiver in my closet I never planned to use again. My thought was: even though it wasen't the exact model receiver, it did use the same remote, so the frquency that the Photoamplifier worked at should be compatible.
So I took apart this receiver unsoldered the Photoaplifier. I then removed the Photoamplifier from my malfunctioning DVR and installed the part from my unused Receiver and it fixed it. So long story short(too late for that) the Photoamplifier was faulty. I tried doing some cross checking and a company in China called Raytron makes the part. The failed part did not have a part # and Raytron has several different Photoamplifiers that operate at different frequencies. This made it impossible to find the right part without schematics or knowing what the freqency is. So at least we now know what caused the non responce to the remote.
Posted on Aug 03, 2011
How do I download the DirecTV app to my Roku streaming stick?
Roku is a streaming device to download the DirecTV app:·You have to press the "Home" button on your remote.·Scroll down and select the streaming channels.·Enter the "Direct TV"app now in the search box.·If require, you have to enter the Roku pin. ·Now DirecTV app will be installing on your Roku TV. Enjoy...
Oct 12, 2016 | Roku Televison & Video
Just hooked up the streaming stick to HDMI to the TV. nothing is showing up, What do I do now?
Sounds like you have a bad connection on either your roku stick or your HDMI PORT.Does you ROKU stick show a white light if not check power cable or electrical plug.
Try wiggling ROKU stick just a hair or push it in and out until you get a signal..A purple screen with the words ROKU should show up on TV.If you have a bad port on TV it would have to be replaced but this is rare,if you have a second port on tv try that.Have you tried your ROKU stick on another tv?Does your streaming stick go in vertically or horizontally,if it goes in vertically it may be pressing against side of tv prohibiting a good connection.You could try a HDMI cable, plug the HDMI cable into tv and put ROKU in other side of cable.There is also a restart button on ROKU stick push it and it will start blinking,if it doesn't light up you may have a defective ROKU stick.
Feb 25, 2016 | Roku Streaming Stick HDMI Version
How do I hook my tv to Netflix without a cable
Hello Anony, the best way is to buy a 'dongle' there is several the one that comes to mind is ChromeCast, from Google. Hope that helps Anony. Cheers Greg.
Mar 04, 2015 | Netflix
How to use Roku with HDMI Panasonic TH-50Px25
You will have to set the HDMI input to the port you plugged the Roku in. From there, you should be able to see the program screen.
Feb 26, 2015 | Roku Televison & Video
How to hook up a Roku2 to Sony KLV-S32A10 TV with A/V cable (yellow/red/white Ports)
If you plug into the box and TV with the composite plugs then you need to change inputs. Your TV is currently set to use HDMI. You need to change the source with your remote.
Dec 25, 2014 | Roku 2 HD
TV doesn't recognize HDMI with Roku
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Jan 13, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Oct 13, 2009 | Denon AVR-4306 Receiver
Blank screen on HDMI connection
I have good new and bad news The good news first: believe it or not you have solved the problem and the HDMI port on you TV is not working. Now for the bad news: What ever damaged the HDMI port on your TV also damaged the DVR UNIT, and it looks like it could be in the switching section. What that is is the point where viedo is delivered to the various ports by the DVR Unit, I should call it more of a crossover point,since the signal is processed differently by the various output ports. I would suggest that you get the HGMI port in yoyr TV repaired and the DVR repaired at a qualified shop. There are no repairs that you can affect on these devices.
Sep 07, 2007 | Directv HR10-250 DTV Receiver
Televison & Video Logo
26 people viewed this question
Top Directv Televison & Video Experts
john milligan
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
