Question about Miele Washing Machines
Miele Dishwasher won't run. G4220. Fills and empties ok. Originally had F13 error. Circulation impeller has been checked and turns ok.
Had F13 error and eliminated a few things and settled on the Flowmeter board. We replaced this twice. After the first replacement, the machine filled intermittently (5 secs fill, 4 secs rest, and repeat) until it reached the correct height in the dishwasher. It then started to drain and continued to intermittently fill. This went on forever until we turned the machine off. Second time we replaced the flowmeter board, the machine filled properly (in one hit, not intermittently) and then stopped and clicked for about 5 minutes. Two clicks - one from the control panel area and another from somewhere underneath. The clicks were 8 secs and then 16 secs apart, then repeat. Eventually, machine stopped with F14 error code. I have read somewhere that when the flowmeter board is replaced, the flow count needs to be reset. Does anyone know about this and, if so, where I could get instructions to reset the flow count. Given the error changes with each flowmeter board I feel I am on to something. Thanks, Tracey Solved. When we checked the circulation pump, we had not replaced the power connector to the pump. Once we plugged that back in all worked ok. So... the fix to the original problem was replacing the flowmeter board.
  • Miele Master
  • 20,450 Answers
Tracey, the original poster found her own answer to the problem which is listed here for those with the same problem.
Thanks, Tracey Solved this.
When we checked the circulation pump, we had not replaced the power connector to the pump. Once we plugged that back in all worked okay. So... the fix to the original problem was replacing the flowmeter board.
Posted on May 30, 2017
Miele dishwasher fills with water when not being used. It could overflow if not turned on to empty the water. Shows f13
Sounds like the fill solenoid is letting by. You'd need to replace it and that should sort it out
Dec 02, 2017 | Miele Dishwashers
F3E error
Check the circulation pump.
Jun 22, 2013 | Miele 24 in. G638 Plus Free-standing...
My Miele dishwasher has water in the bottom of it and won't run
Check the impeller on the pump to make SURE it's turning freely. There could be a piece of debris wedged in there - like glass or a screw from a pot handle. If this is redundant, I apologize.
May 24, 2012 | Miele 24 in. Novotronic G851SC Plus...
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
F14 code Miele Dishwasher
This fault is low pump pressure. more than likely you have some foreign particles jammed in the circulation pump. you would have to remove the unit, tip it on its side and remove the bottom plate and remove the circulation pump and clear the blockage. the unit will start and stop and not work until the pump is clear.
Aug 14, 2010 | Miele Premier-Plus Built-in Dishwasher
F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Apr 20, 2010 | Miele Premier-Plus Built-in Dishwasher
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Circulation pump is stuck
Hello Stonegroup,
The impeller is located below the bottom filter trap. Remove the tray and at the twelve 'O' Clock position you will see a small opening. Inside there are the pump impellers. take the Hackenschlussel (Hook spanner/Miele tool) and insert it in the opening and turn. You should turn it a few times and be able to feel the impellers free up. Also, Make sure you run the dishwasher atleast once a monch to avoid the circulation pump getting stuck like this
Sep 17, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Washing Machines Logo
124 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
