Picture of how spring and rubber go on - Washing Machines
Need repair instructions
cleaning and replacing rubber on the bobbin on top to wind bobbin and the spring was just laying in machine....can anyone have a picture to let me know how it goes back in.
Jun 29, 2012 | Sewing Machines
I have had my Delta bathroom faucet about four years. The hot water side drips. Can not get it to stop. It is one faucet with hot and cold handles with all sitting on a small platforum. The platforum is...
Go to delta website, take a picture of faucet with your cell phone and send. They should be able to identify and send you the parts. Meanwhile you'll have to turn water on and off from the emergency shut off valve under the sink. If it looks like the picture, it's probably the rubber seat and spring. If you don't want to wait go to your local "hardware" store. There may be someone there to help you. Bring the stem or cartridge, along with the rubber seat and spring. Don't use cold water while stem is removed. Turn cold off as well to prevent a mishap.
Apr 23, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
Seems load is out of balance
Your washing drum is spring balanced and your
motor has rubber shocks to keep it balanced so check
both for damage. _( cracks in rubber shocks and breaks in
washing drum spring or springs ) Also springs or rubber
shocks are no longer fastened to motor or chassis.
Feb 11, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
A sheet in the washer got tangled in the rubber door assembly and pulled the rubber away from the housing. The rubber is still attatched to the main body, but right by the drum the rubber and the metal...
To get the clamp back on you'll need to fit the rubber part on first. Then begin working the wire part of the spring clamp back on, starting 180 degrees away from the spring. As you work it back on and into the groove, it will become harder to get on. When you can't go further, carefully lever the wire and spring over the lip and into place with a small screwdriver, or similar, being careful not to pinch or tear the rubber bellows.
Best regards,
--W/D--
Jan 21, 2011 | GE WSXH208A Front Load Washer
Rubber around the washer has come off - there is a thin mental wire but it does not seem to fit well. I have also lost the manual which may have a picture in it.
The thin metal wire should have a loop on either end. Connecting the two loops is a spring, that wire/spring combination holds the rubber seal around the tub opening. Putting the wire back on is a lesson in patience. The rubber fits in a slot on the back and the wire holds it in in the front. Good luck.
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Rubber ring on the front wheel springs or shocks broke is this important can i still drive it
I quess you mean rubber ring under front spring.
I would pull the spring/strut and replace whatever it needs.
It will effect ride height to some extent,thus alignment,and could causes issues with wear,noise,etc,to the spring seat. You could drive it for a few days,until you find a shop, you want to repair it.
On an 8 year old veh,you may as well just install new struts,as well as new spring rubbers or now they have complete assemblies ready to go in.
Sep 09, 2010 | 2002 Ford Explorer
I need to replace the door lack how do i do it??
the front boot can be pulled off from the front to get to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door rubber for Zanussi Jetstream Excel 1200
Hi.
It is a sod to get the spring on .
Make sure the rubber is on securely, and then gradually feed the spring round the rubber starting at the top.
It will get more difficult the further round you get, If you can get someone to hold the spring for you when part way round, you will get it on.
You can also try stretching the spring, which will make it easier to get on .
Good luck.
Nov 21, 2008 | Zanussi Washing Machines
Changing front loader seal
the way i done it was open the door take take the wire band of around rubber seal__as in picture one.__2 take top of machine of and take spring of as shone in picture 2 you shold be abble to take silver band of around rubber seal
Dec 11, 2006 | Hotpoint WMA58 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
