Question about Drills
Mastercraft 18volt drill -need reverse switch
stug_57u
  • 99 Answers
SOURCE: bosch psb 600 drill will not reverse
The red button sits on a lever that changes the polarity of the switch output. If this lever feels loose and you can't feel it engaging anything then you need to split the housing and make sure it is seated properly. If it is, and the lever on the switch is moving fine aswell then you should check all the wires coming out of the switch, and if they are all connected properly you will prob need a new switch.
Posted on Oct 26, 2008
stug_57u
  • 99 Answers
SOURCE: dewalt 18volt drill xrp dc988 in pieces
If you are in the U.K. go here fore tech help and service dealer locator etc https://service.toolcommerce.com/products/HomePage.aspx?BrandId=2&language=en-GB&country=GB
If you are elsewhere go to www.dewalt.com and you can navigate to other countries etc from there.
  • 101 Answers
SOURCE: Broken Forward/Reverse Switch on Bosch Model 1198VSR Hammer Drill
Yes .. should find it here http://www.toolpartsdirect.com/bosch-tool-parts.html
Hope this is Helpful ! Thanks
Posted on Dec 16, 2008
SOURCE: Mastercraft hand drill, is not working,simply shut down during
Same tool, same problem, same research.... and we both have the same last name ! Found anything ?
Posted on Jul 20, 2010
  • 30 Answers
SOURCE: I am interested in purchasing
Manual appears to indicate it has a forward/reverse switch http://www.milwaukeetool.com/PartsAndService/DownloadManuals/All.aspx?ProductId=0200-20
Posted on Jun 13, 2011
I have a mastercraft industrial reversible drill. Model number 1540. Looking for a replacement handle with the power trigger and reverse switch. Anyone know where I can get replacement parts?
this picture of the drill is familiar or similar to a "skill" made drill
talk with a service agent for skill, B&D woulf machines and you may get a cross match or even a handle from a failed drill
Jul 23, 2015 | Drills
Need manual for mastercraft 10" drill press
Your best way is to contact Mastercraft tools; you'll find there information on the attached link. http://www.mastercrafttools.co.za/
Feb 22, 2015 | Drills
The chuck on my 18volt drill will not hold a drill bit long enough to drill one hole. i have 3 of these drills they all do the same thing
Hi. I'm guessing it is a keyless chuck. I always have to use two hands to tighten mine. Is drill running forward and not in reverse?
Sep 10, 2011 | Garden
How do you remove the chuck on a 18volt Dewalt drill.
the chuck is held to the drill by a small allen head screw that is down in the base of the chuck -- it is a reverse thread.
after the screw is removed - the chuck should pull off.
c...
Jan 24, 2011 | Garden
18volt cordless drill stopped working. Exchanged batteries but still will not turn on.
Howdy. that brand is notorious for poor quality manufacturing, and short life. If you have purchased it recently, I would recommend returning it and getting a slightly better brand. Here is the link to their warranty and rma pege if you want to have them repair it, though:
http://www.buffalotools.com/Magic/mgrqcgi94.exe?appname=BTWeb&prgname=WarrantyCard
Not all Chinese products are equal. Some are really well made now..but, some aren't. :)
Just remembered that machine sometimes has a glitch in the forward/ reverse switch. flip it back and forth a few times and see if that makes a difference. Hope so.
Regards,
Farmerbear
Aug 30, 2010 | Buffalo Tools COCD24 24 Volt Cordless...
Dewalt chuck removal
there is a screw inside the chuck inline with it, I believe it has a reverse thread so turn it counter clockwise to remove
Jun 28, 2010 | Dewalt DCD950VX XRP HeavyDuty XRP 12"...
Pro tech 18volt. Item number 6810
http://www.sears.com/shc/s/p_10153_12605_00981808000P?vName=Tools&cName=PowerToolAccessories&sName=Batteries%20and%20Chargers&psid=FROOGLE01&sid=IDx20070921x00003a
Mar 27, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
When i drill with my 18volt cordless, and the bit catches it makes an awful grinding noise inside the drill, its not the adjustable clutch set low. its set on drill?
Your speed switch is between gears, pull the trigger lightly and slide the speed switch back and fourth until it is fully engaged. Also turn the clutch setting all the way down then all the way back to lock it is not uncommon for them to get dodgy.
Cheers,
Kevin
Mar 23, 2010 | Dewalt DC6PAKRA Heavy Duty Xrp 18volt...
Drills Logo
43 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
