Question about Mini Audio Players & Recorders
Sound link mini Power outage speaker shut down only red light does not work
SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Posted on Mar 27, 2008
Ajkill
  • 2035 Answers
SOURCE: Blinking Red Power Light
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..Try to plug different power source if this fails ,then you give it service center to get it fixed or you like DIY then :
I would recommend going to the following link and getting the service manual so you can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new board. heres the link.
http://servicemanuals.vstore.ca/
Posted on Sep 17, 2008
yambo
  • 230 Answers
SOURCE: red light flashes,10 sec after turning on. after power outage
Hi, thank you for visit fixya.
Do you need replace both stk 392-110, and check any resistor (2.2 ohms) for blown or open. You can replace this IC's for stk 392-150d9f769b.jpg
Posted on May 12, 2009
  • 4 Answers
SOURCE: red staus light after power outage
when the outage comes it is because of a sharp burst of energy that is fast and then stops i have had similar probloms.try to take it in and you will have to have them look at the chip
Posted on May 27, 2009
mbelectronic
  • 147 Answers
SOURCE: power light blinking RED after power outage
replace the power pcb,check the fuse on the
power pcb and see if that corrects your problem.if not replace the power pcb.go tp
shopjimmy.com to get the board.
Posted on Jul 29, 2009
Power outage Bose shut down just red power light nothing works
Look for bad filter capacitors in the power supply. There may be a fuse blown too.
May 11, 2017 | Bose Audio Players & Recorders
Does the light flash a certain number of times? how long have you owned the television? Once I have all the needed information I can provide you with the best solution.
Thanks,
Lee
Sep 16, 2008 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
My bose soundlink mini won't charge or turn on worked fine for a while but now the red battery light is flashing fast every time I try to charge it it's been on the charger overnight and is still doin so...
I love my Bose Soundlink Mini 2. But, I faced a few issues sometimes.
Speaker not turning ONSpeaker not charging with the battery LED blinking.Speaker not getting connected to the bluetooth devices.
But all were fixed by reading through the Manual a bit. To help others, I actually made a video, to show some troubleshooting tips for the Bose Soundlink Mini 2. Checkout the video, if your speaker is not turning ON / not charging / bluetooth not getting connected:
This seems like a very common issue for the soundlink mini 2. This is due to a firmware bug. Gets foxed with a hard reset.Check the video for details and other trouble shooting tips.
Feb 22, 2014 | Cameras
It has stopped workin and the red light is flashing.Is this a code and if so how do you read it
The red light is a power protection circuit designed to shut the amplifier down due to an overload or wiring problem. If the amp was playing then shut off, my guess is a problem with the speakers or the speaker wiring. Some amplifiers are only stable to a certain load. For example, most car audio speakers are 4 ohms which is the resistance placed upon your amplifier to produce a certain volume of sound. If you bridge two 4 ohm speakers together in parallel, you cut the resistance in half, thus increasing the amount of power (and volume) to your speakers. This also creates more heat and could, in effect, shut your amplifier down. I would find out how the speakers are wired to determine the resistance of the load your amplifier is pushing. Also check the grounding.
May 26, 2011 | MTX X Thunder 300XD Car Amp
I have 4 wires, red (power(, black (ground), green (speaker), gray speaker...the stereo has these same color wires...so I connect the corresponding color. The boat has NO yellow battery wire that is on the...
(http://inform3.kenwoodusa.com/manuals%5CKTSMP400MR.pdf )
Here's a link to manual and wiring on page 30 on the PDF file.
Yellow is constant power from battery, for memory etc. Red should be to switched source.If need be, you can connect both to battery, but remember, you'll have constant power draw on battery when stereo left on but switch turned off, and will draw battery down, if you forget to shut it off, and leave the boat. Speaker negatives to black should work but I would advise hooking my 2 right and 2 left + speaker wires from stereo together, then to one of the speaker positives,right or left for better sound. Fronts will usually supply higher ( high and mid range), and rears will supply lower sounds (woofer) Joining them together will give better sound usually, when only using 2 speakers, on a 4 speaker stereo. You may want to test with them joined and not, to see what sound you like better.
Sep 26, 2010 | Kenwood KTS-300MR CD Receiver
Amp wasplaying red light came on and won't go away i check ground and it is good
Jun 20, 2010 | MTX Terminator TN400/4 Car Audio Amplifier
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
Apr 17, 2010 | Marantz SR4002
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
Red light flashes,10 sec after turning on. after power outage
May 12, 2009 | Panasonic PT-53WX42 53" Rear Projection...
There is a flashing red and then shut down NV-DS65
battery is not charged or is defectived. or the power supply is not working.
i suggest replacing the battery or getting a new power cord
Apr 23, 2009 | Panasonic NV-DS65 Mini DV Digital...
35 people viewed this question
Top Mini Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Are you a Mini Audio Player and Recorder Expert? Answer questions, earn points and help others
