Question about Westinghouse Televison & Video
Bought a westinghouse tv from goodwill, universal remote no source button or ok button and tv won't let me switch source and has a password to put in to reset settings.. Model # WD32HT1360
  • Westinghouse Master
  • 3,047 Answers
Hello Peter Ramirez,
No need to suffer any longer...
Get onto eBay (below)... $7.99 and FREE shipping...
New Original Westinghouse RMT 24 TV Remote Control DWM48F1Y1 DWM32H1G1...
Carnac the Magnificent
Posted on May 12, 2017
  • Peter Ramirez
    Peter Ramirez May 12, 2017
    But how does that bypass the code I have to put it to change the settings ?
  • deton8 von Splosion May 12, 2017
    Without the IMMITATION REMOTE...
    You should have no codes required.
    If you are talking about
    "parental" controls... You should go to manualslib and get your owners manual...
    Read it and do a GENERAL RESET to clear...!!
  • 230 Answers
SOURCE: universal remote magnavox model # CL034
here you go
Posted on May 15, 2008
SOURCE: Programming code for GFM LCD TV
Hello Sandrp,
I too had been looking for a code to program my remote. The problem was that GFM is not a recognized TV company like most other companies. So I figured it must have been done by another company and Meijer just put their brand on it and I was right. The company that made the TV is Funai. If you try looking for that company in the list it may be their. I know I was able to find it for my Directv remote. Hope this helps.
Posted on Aug 24, 2008
SOURCE: Code for philips universal remote CL019 for White-Westinghouse Tv
Thank you for your inquiry about my problem. I actually found my manual today!! I was so happy. Thank you anyway.
Posted on Dec 15, 2008
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Posted on Feb 03, 2009
  • 1746 Answers
SOURCE: universal remote (GE 24116) that
Hi, You need a code to match with your TV remote. The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
Posted on Sep 09, 2011
I have a Westinghouse LCD tv and i lost the remote but in trying to run auto scan and it keeps telling me to press enter but I don't know how to
WESTINGHOUSE LCD-TV USER MANUAL Pdf Download. > ... > Flat Panel TV > LCD-T
Westinghouse Digital 27'' Wide-Format LCD - TV User's Manual. ... the analog cable or TV antenna wire (not included) directly to this LCD-TV antenna input. ... a list of video sources using the SOURCE button located on top of the LCD-TV.
images for Westinghouse LCD tv enter button location
Sep 28, 2015 | Westinghouse Televison & Video
How do I switch the TV from cable to regular TV
Depending on your TV make, normally hitting the antenna button will switch you from cable to antenna (regular) TV.
Aug 24, 2015 | Video Game Consoles & Games
Need a universal remote code
Try 0000..
If that doesnt work I have another solution for. Westinghouse flat panel TV
TV 10812 probably has the correct IRsignalsfor enter programmed to the ok/select button. However the comcast and access remotes are intended to control a cable system so even in tv mode the remote sends the digit, ch+1and enter signals to the set top box.
There are two ways to defeat this.
1)Turn off channel lock. Sethe 9xx comand for this.
OR2) Assign a EFC for the Enter signal to the device mode.
1) Press TV
3) Enter 994 (two blinks)
4) Tap setup(DO NOT HOLD)
5) Enter 00069
6) Press ok/select.
The remote should blink twice and the ok/select button should work in the tv mode.
Use 1 unlessyou're going to use remote with cable box.
I hope this works...
Dec 17, 2014 | Westinghouse Televison & Video
My onn universal remote codes doesn't not work on
Common problem with universal remotes, you can try programming the remote with a slightly different model or brand and see if it does better. Mostly, just learn how it works and deal with it; or try out a different remote. My TV remote and DVD player remotes could both act as universal remotes, but the DVD was much better at it, so we used that one.
Apr 02, 2012 | Televison & Video
Remote won't detect TV
as it a learning feature if so perhaps it could learn from the original controller. i have had universal controllers in the past that are rubbish and certain makes/models can't be controlled...
May 03, 2009 | One For All URC-4021 Remote Control
Channels blocked, no manual, and only a universal remote
Call the customer service number on the set.
Oct 29, 2008 | Durabrand DU1301 TV
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Game Mode
I have the Xbox 360 remote... It works! ^_^ its $19.99 at best buy. When you programming it just hold down the TV and ok button. The number lights are going to stay on... put in 0445 the push the channel button up and down the TV will turn turn off/on. Then push the input button and you’re done. Hope this help.
Aug 29, 2007 | Symphonic ST419E TV
Televison & Video Logo
66 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
