Question about BIT Garden
Tractor starts and runs for a little bit and then runs out of gas
There is gas visible in fuel filter and then I start mower and then it runs and then stops after a little bit and there is no fuel showing in the fuel filter
    Top Expert:
  • BIT Master
  • 40,764 Answers
Low/no fuel
blockage in the filter in the tank
blockage in the metal fuel tap at the tank
Posted on May 12, 2017
SOURCE: mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Posted on Mar 30, 2009
jmgldsmth
  • 1869 Answers
SOURCE: mower starts w/ priming but stops after 1-2 seconds. Air filter, gas, oil, spark plug are new
Remove your fuel filter (in the tank usually) and, replace it
Posted on May 20, 2009
SOURCE: Craftsman 17.5 hp 42 in. Deck Lawn Tractor
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
Posted on Nov 28, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
  • 173 Answers
SOURCE: four stoke mower. Mower starts and runs ok but
Your ignition coil is failing when it gets hot.make sure the cooling fins on the flywheel are not plugged up.you will probably have to replace the coil.
Posted on Dec 28, 2010
I am having trouble starting tractor. It stalled facing uphill. Fuel filter half full of fuel. Doesn't seem to be getting fuel. Plenty of crank power. Any suggestions?
fuel ran out of float bowl no gas coming into float bowl needs and seat installed in carb tap carb with screw driver to try to get bowl to fill and start it with a little with a squirt of starting fluid in carb if runs rebuild carb it will run
Sep 10, 2014 | Garden
My Craftsman Lawn Tractor 18.5, 42"Mower with Electric Start and Automatic Transmission won't start. (model# 917.275760) won't start. I have put new air filter, fuel filter, battery and spark plug...
Try looking at the screw that holds the bowl in place, sometimes they have a little orifice on them that gets clogged and hinder fuel from reaching carb. Use a small pin or small gauge wire to clean. Good Luck...
Apr 21, 2011 | Garden
Mower starts out with a full gas filter for about 25 min. then starts to sputter and barely has a trace of gas in the filter.
It doesn't have to have a full filter to run, but the sputtering and fuel line volume indicates fuel starvation or a type of vapor lock (from a vacuum situation). A mower like this has to vent the fuel tank or it will only draw a while and then no more. Your gas cap's threads are the actual vent for the tractor. Try running it with the cap on somewhat loose, Post back if needed.
Sep 13, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Cub cadet lawn tractor, ran out of gas. After
I would bet that the throttle shaft is worn and has a lot of play in it on the carburator. This is very common. The best bet is to have the carburator worked on by a small engine repair shop, or get a replacement one.
Apr 16, 2010 | Garden
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower dies
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
Nov 02, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
27 people viewed this question
Top BIT Garden Experts
Bill Boyd
David Hoover
Level 1 Expert
Jim flowers
Jim flowers
Are you a BIT Garden Expert? Answer questions, earn points and help others
