Question about Bose Audio Players & Recorders
Power outage Bose shut down just red power light nothing works
  • Bose Master
  • 9,742 Answers
Look for bad filter capacitors in the power supply. There may be a fuse blown too.
Posted on May 12, 2017
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
Bose L1 System 1 Shut down during a show but the fuse is good. Nothing works, not even the lights.
Sorry to say that if you're sure that you have a good power source (cable and outlet), then if you've got no lights on the Power Stand, you'll need to talk to Bose L1® Support.
Call Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
Monday-Friday: 8:30 AM - 9:00 PM ET
Saturday 9:00 AM - 5:00 PM ET
Or write to them on the Bose Forum.
Ask Bose for Help Forum
Oct 21, 2013 | Bose L1 Speaker
Computer wont turn back on after power outage
Power surges are like Radiation poisoning: the effects are cumulative. You need to have it on a Surge Protector (not just a power strip with an over-amp cutout,) that is AT LEAST 1200 Joules. Much higher if you live in a lighting-prone area, or are subject to frequent power-outages. Your Power Supply Unit appears to be on the edge of failing. I suggest you get it replaced IMMEDIATELY. A PSU with issues such as yours have been known to damage one or more of the other components inside your PC when it finally dies.....like the Hard drive, or a Memory module...even the CPU.
Aug 22, 2012 | Systemax Computers & Internet
I had a power outage. When I turned on the Dell it came on but said the DSL didnt connect so I shut down. From that point on, I only get the bliking amber light when i push to start up. All the other...
From what I am understanding you are having issues connection to the Internet after your power outage. If this is the case you would need to power cycle everything,
Start by shutting down the pc from the start menu.
Remove the power from your router and modem,
You will need to wait 30 seconds before you can plug the modem back in, once all lights appear on your modem replace the power to your router.
Once all the lights on the router appear...Power the pc on. This should resolve your issue.
Mar 30, 2011 | Dell Dimension 3000 PC Desktop
My dell d600 doesnt start after a power outage. It was plugged into a power surge protector. This has happened before (power outages) and never a problem. After this outage, I was able to get online for...
A little googling gave me this http://www.laptop-junction.com/toast/content/dell-caps-lock-light-flashing-blinking
Looks like it could be a memory problem. You could check if one or both of your memory is damaged by removing one at a time. The manual should have the procedure for adding / replacing memory.
Feb 21, 2011 | Dell Latitude D600 Notebook
Alarms will not work
Hi. Often following a power outage there is a power surge when the power is restored. If you do not have your Bose protected by plugging it into a surge protector, an internal fuse will blow to protect the rest of the radio. Once that fuse is replaced you will be back up and running. J.
Jul 09, 2010 | Bose Wave Radio II
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
No sound
Unplug it then plug it back in, it will reset something and then will work fine, probably caused by a power surge or power outage. Hope this helps someone, God Bless.
Sep 28, 2007 | Bose 3 2 1 GSX System
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
