Washer won't drsin. Water gushes from under the door. What should I look at?
5 Suggested Answers
  • 10 Answers
SOURCE: Water gushes out of the inside of my Karcher jet washer.
you can sometimes seal the water leak from the inside as I think your water inlet case has split
Posted on Jan 07, 2009
  • 24 Answers
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Posted on Apr 18, 2009
jsrock516
  • 5911 Answers
SOURCE: Duet 9150 washer collecting water
The problem is more than likely your water inlet valve. The water inlet valve (also known as a mixing valve) is located in the rear of the washer where the fill hoses attach. There is a separate solenoid for the hot and cold water. These two valves are controlled electronically, but the small diaphragm that controls the water turning on and off can become clogged with sediment, or the solenoid can stop working, causing it to not close properly when not in use. With the diaphragm stuck open, the water will leak by and fill the drum over time, causing the problem you are describing.
Long story, short...you can attempt to remove the water inlet valve and clean it with some distilled vinegar and water solution. Or, you can simply replace it with a new one. In either case, you will need to access it and remove it from the washer. The following steps explain how:
1. UNPLUG the washer.
2. Turn off the water supply and remove the fill hoses from the back of the washer.
3. Remove the washer top panel by loosening the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
4. The water inlet valve is in the rear of the washer on the left hand side (as viewed from the front). Remove the water dispenser hose and disconnect the electrical connections.
5. Loosen the mounting screw(s) that hold the valve in place and remove.
You can attempt to clean the assembly in a 50/50 solution of distilled vinegar and water by allowing it to soak for about a 30 minutes. Mix a solution in a container and submerge the valve portion only, leaving the electrical contacts dry. After 30 minutes flush with warm water water. Sometimes this works, sometimes the valve needs replaced. In my own personal opinion, if you're going to go the route of removing the valve, you might be better off to replace it to save yourself from having to repeat these steps twice.
Replacements can be purchased on line at appliancepartspros.com, searspartsdirect.com, repairclinic.com, or pcappliancerepair.com. All these sites offer great service with competitive pricing, so shop around for the best price. I hope this helps you.
If you have any questions, please let me know.
NOTE: I would recommend you turn the water supply off while not in use until you can resolve the problem. This will prevent the tub from filling.
Posted on Jul 06, 2009
TheMobilian
  • 8220 Answers
SOURCE: I HAVE A FRONT LOADER, WATER NOT DRAINING
Start here0e4f85f.jpg 8a7ddc2.jpg ce6b1cf.jpg88e38f7.jpg d13de4f.jpg .635d190.png
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 15, 2010
My front loading LG washer is not draining. Water gushing from under door.
No draining is most likely the pump motor. Washer door not closing tightly is rusty hinge most likely. What's the model number? Post photos if you can.
May 11, 2017 | LG Washing Machines
When I start the washer, it fills just fine with no problems but once it starts the cycle, it gushes water from the bottom of the door
Check the bottom of the plastic inner door. If there is a crack or a gouge, have it replaced. Also check the rubber door boot for holes above the water line
May 09, 2014 | Maytag Neptune MAH5500B Front Load Washer
Kenmore washer 600 series model 11027642600
Could be bad hose, valve or seal in the washer (this was listed under dryers). Requires taking the washer out of service and looking for source of the leaks. Hose, valve or connectors is more likely than a seal if water is gushing.
Jan 11, 2014 | Washing Machines
Kenmore HE3 washer water flows out of bottom
check your door seal first.,
take your kick panel off
3..... 7 millimeter screws or t15 torques
check your hoses
check your drain
more than likley it's your door seal
you can also take the lid off same way you took the kick panel off
let me know what you find
May 04, 2010 | Kenmore HE3T Washer
How do i get the machine to drain the water out.
you will need to run it through its cycles to get it to drain.
Jan 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Mar 06, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
Top Washing Machines Experts
