Question about Viking Ovens
My Viking double oven French Door Model VDOF730SS has an F03 code for the top oven and will not heat up. What's wrong?
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
  • 5 Answers
SOURCE: I have electric double oven VEDO275SS by Viking
you need to have a new thermostat fitted or the old one re callibrated if possible
Posted on May 29, 2009
  • 212 Answers
SOURCE: Main oven doesnt heat up. But temp light is on.
replace heating element
Posted on Jun 22, 2009
  • 69 Answers
SOURCE: I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Posted on Aug 17, 2009
Part numbers for door gaskets Viking double oven ved0530ss
Go to searspartsdirect.com with your model number. You'll find parts lists and diagrams there
Dec 01, 2017 | Viking Ovens
I have a Viking double wall oven model DEDO130. I have terrible baking results in the upper and lower. Mostly burning the tops (pizza, biscuits, etc) while the centers aren't done. A tech from the...
Home > Cooking Parts > Wall Oven Parts > Control Panel Area > Oven Thermostats >
G50012998 DESO SERIES T/STAT KIT Viking Electronic Part. ALL SALES ARE FINAL.
Viking Thermostat Replacement Kit
btn_emailafriend.gif pbox_border_left_top.gif clear1x1.gif pbox_border_right_top.gif clear1x1.gif G50012998 DESO SERIES T/STAT KIT Viking
List Price: $189.14
Our Price: $133.83
You save $55.31!
Return Policy Electronic Part. ALL SALES ARE FINAL.
Availability:: Usually Ships in 1 to 2 Business Days Subject to Stock Availability - Call to be sure.
Product Code: G50012998
The part is not that hard to replace. but it is expensive. In my opinion it should correct your problem since you have that much difference.
clear1x1.gif pbox_border_left_bottom.gif clear1x1.gif pbox_border_right_bottom.gif
Jun 08, 2011 | Ovens
My Viking oven door will not open after self cleaning 3 hours ago
not sure. its possible that something melted into the hinges and glued it shut. or i guess if it got hot enough the metal could have been heated up to a point where it was bent out of shape and thus it got stuck
Nov 04, 2010 | Viking DEDO205 Stainless Steel Electric...
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
Wehre is model number located on viking oven?
It is usually on the stove at the bottom of the oven door. you might have to remove it to read it properly
Sep 18, 2009 | Viking Ovens
Aug 17, 2009 | Ovens
Oven doesn't heat up to the right temp--lower oven Viking Pro
Adjust the knob to the actual temperature. There are usually screws inside toe back of the knob for this purpose.
Mar 23, 2009 | Viking DEDO205 Stainless Steel Electric...
Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
Dec 01, 2008 | Viking 27" Professional Select Built-in...
Ovens Logo
112 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
