Can't get one channel to come on. It worked fine then all of a sudden it just skips to the next channel.
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Suddenly, can't get all the tv channels!
Try resoldering where the tuner mounts. Rca has had some problems with solder connections
Posted on Jan 21, 2008
  • 282 Answers
SOURCE: Can't get channel 29 to come up. Tv worked fine, then now it skips to the next channel.
If you can get the channel by entering the channel numbers ( ie; the 2 and the 9), then you need to re-initialize your TV. Do that by going to the main menu and selecting a channel scan - it should find all channels that are available in your area.
Posted on May 11, 2017
Go to your TV settings and manually add the channel. Sometimes if TVs don't detect a signal from that station it Auto deletes that space
May 11, 2017 | Televison & Video
Skip channel function not working coreectly
db:: 4.90::Fios tv VMS1100 skip not working correctly k3
www.hivmr.com/db/k37cmjfzkk71s913ksf3j7xfxsz3zc37
DB:4.90:Fios Tv Vms1100 Skip Not Working Correctly k3 ... Pressing Play on the remote has no effect, but changing the channel fixes everything. ..... The functions Skip Forward, Skip Backwards, Next Chapter and Previous Chapter all skip ...
The Secret Method to Skip Commercials with One Button on ...
Dec 28, 2015 | Televison & Video
How can I get my RCA 5 disc CD changer stereo to work right?
I have an RCA 5 Disc Changer, purchased at Target. The first one had a prolific issue of skipping on discs. It would play part of song on the first disc then suddenly change to the next disc. However, it did not ALWAYS do this, just sometimes, seemingly at random. Then one day, it would suddenly work just fine on all 5 discs. Eventually it simply would not play an entire song at all, so I took it back (within the time of the warranty). They had 1 of the same left on the back shelves so was able to get that one. This one started doing the exact same thing within the month. Now, it will not READ discs. It will simply read, 'Read"..and then when it comes up showing the disc number it has all zeros. I tried skipping to the next disc and then the next, and suddenly it read. That was fine for two days, then it would not even do that. I tried using compressed air inside all of the open disc drawer, and on all the discs but to no avail. Just now I tried tilting the entire unit Back at about a 30 degree angle and while in that position hit the 'disc change' button on the remote and suddenly it read. How long will this work? Have no idea. Very irritating - and it's hard to find this kind of player anymore, apart from a Component System which is a whole new playing field. Amazingly , I had bought my first changer, a 6 CD changer, cheap one at wal mart long ago and it lasted me about 10 years and never had a problem. It was a no-name brand too, I would expect better from RCA but alas, tis not the case.
Jun 05, 2014 | RCA Audio Players & Recorders
HI...This is Bhushan here, It is nice to see that Fixya is reaching out to people to solve any electronic gadget related problems. I would be obliged if you could solve my problem too. A friend of mine...
Before you dive off into electronics, first set it on a channel and throw a cover over the front of it to cover up the infrared receiver input. It may be something in the room transmitting spurious signals.
Oct 26, 2010 | Audio Players & Recorders
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Channel keeps skipping on rca t.v
Problem with channel skipping has rectified itself. I simply unplugged the set and and started over with remote intructions on signal and channel setting. The tv was also turning itself off and on, this also has ceased. Thanks, hope I don't need you later.
Nov 24, 2008 | RCA Universal Remote Control
Oct 16, 2007 | RCA F36649 36" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
