Supply latex mold making liquid - Washing Machines
Why does my LG top load washer have mold in the detergent area?
This is a common issue, they make cleaning products to remove this gunk. Hot water and bleach will kill it as well.
Feb 01, 2017 | LG Washing Machines
Draggingclutch
are you talking car or lawn mower
have you just fitted a clutch kit or what has belts to do with it
when making a sentence use breaks between the words so that sense can be made of the statement
Jul 30, 2016 | Miscellaneous
1 gallon of any liquid, poured out at 1 mil wet film thickness, will cover approximately how many square feet?
One gallon when applied to a horizontal wall will cover 820 sq. ft. above 87 degrees F. OAT, standard humidity, MSL. thirsty , smooth surface and a way to measure and maintain a 1 mil thickness, in-doors and oil based paint, will skin over as it dries. latex will measure to 1200 sq. ft. @95* F.
Oct 04, 2014 | Tools & Hardware - Others
Interior bedroom wall has paint peelimg off of it
A few issues could cause this, water damage, high humidity, if its an old house mixed paint types (i.e. latex over oil over latex, etc).
Jun 17, 2014 | Tools & Hardware - Others
What are foam mattresses?
Foam mattresses are made of several layers of foam to help cradle your body. There are two types of foam mattresses: memory and latex. Memory foam mattresses are denser and are quite supportive. They are made of temperature sensitive foam which mold quickly to your body. Latex foam mattresses breathe better and are naturally hypo-allergenic. Latex foam mattresses can easily form to your bodies contours but lacks memory impressions.
Jul 25, 2012 | Furniture
I have a LG wave force top loader and I have a mold smell that doesn't go away. I have run the tub clean mode a few time, usually adding bleach to where you would normally add bleach. However I...
I have the same model washer and also have that gross mold smell. However, it has NOTHING to do with liquid fabric softener because I ONLY use dryer sheets.
May 02, 2012 | LG Washing Machines
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
I have mold growing inside where the fan is.
The outer chassis needs to be removed and then gain access to the scroll fan. Once accessable use a mold and mildew remover on everything EXCEPT the evaporator coils. Many mold and mildew removers are very corrosive to evaporators. A well used scotch brite pad works well on any styro-foam and metal. A pot scrubber brush also does a good job on cleaning the scroll fan. Once you finish cleaning use a fresh water squirt bottle to rinse off the mold and mildew cleaner residue as best you can. Place rags in the bottom and rinse. Wring out the rags and rinse again. I personally use Mr. Muscle Mold and Mildew Remover but it is really hard on your hands. Disposable Latex gloves are a must. You will not get rid all of the discoloration off of styrofoam but you will get rid of the smell and the majority of the problem. This is a task a homeowner can do.... just be careful when gain access to the scroll fan.
Thanks for choosing FixYa,
Kelly
Jul 13, 2011 | Frigidaire FAS257S2A WallWindow Air...
How do i get the mold out?
A lot of times liquid detergent and liquid fabric softener will cause this. Dry the door seal after use and leave the door open. Don' t use bleach if you're on a septic system. There are products that are septic safe to clean the mold. Powdered detergent and not closing it up after using should help a lot
Mar 01, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Broken plastic small drive gear.
buy a new icecream maker parts are to get for them.good luck.
Dec 24, 2006 | Rival GC9151 1 Quart Ice Cream Maker
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
