Question about Water Water Heaters
Where is switch for Gas or electric water Heather on Heartland Country Ridge 40 K
GE Smart Water Hot water heater 40 gal will not stop heating water.
1) For gas: Turn off gas to heater:
2) For electric: Turn off circuit breaker.
3) For gas: Copy following link to identify gas control valve thermostat, and troubleshoot by type of gas control.
4) For gas: Gas control valve thermostat has probably gone bad.
5) Add comment and give clear description of water heater.
6) Call plumber.
Feb 17, 2013 | General Electric GE SmartWater Household...
Bosch 125b-ng water heather has low flame only
Did you check to make sure the shut off handle is on the on position?
Dec 19, 2012 | Bosch AquaStar Natural Gas Tankless Water...
How to tell which element is bad in a hot water heather , when the heather have two element.
if you have a multi-meter you can remove the cover plate and check for current flow through the element.
Aug 06, 2011 | Element Chromalox SG1207 430086 Electric...
RHeem 21v40-7 gas heather leaks on the top. Water comes out from all four connections: Cold water in connection, warm water out, rod dip, valve. Do i need to change it? Should I tightened the connections?...
You are sure it is LEAKING pater at all those 4 locations-- correct?
None of the water is from condensation, right?
If you have had pressure water leaks for many years-- then likely a lot of damage has been done to the insulation-- and the sheet metal outer liner?
Does the sheet metal 'skin' (outside jacket get real warm?-- if so, you are loosing a lot of energy -- Probably time to invest in a new, better insulated, and more efficient combustion burner-
and this time, Make sure there are NO LEAKS, when the installation is done!
Mack B
Jul 03, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
The heater heats the water just fine, but after a short while it shuts off and the water becomes cold.
sounds like the unit cant keep up. What I mean is that the water going in is to cold to begin with. All tankless units efeciency is based on the temp of water going in, which their rated between 40-50 degrees on average. Now if you live in the southern part of the country, U.S., thats fine. But if you live in the northern part, it will not work. Im in Vermont and have people in the store about once a month looking for an electric unit, because they dont have gas, And I have to do my best to talk them out of it.
Mar 16, 2011 | Stiebel Eltron Tempra 24 Electric Hot...
Too hot wather/ thermostat problem
its 3 phase not 4 Your wired wrong one of those should be a nuetral or ground
May 10, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
Is hot water present when opening the drain valve. Use a bucket to catch the water. Adjust thermostat from high to kow then prefered detting. Make sure hot water out line does not have a closed valve. If gas, ck pilot. If electric, elements may be damage if heater was powered up before or while initial filling.
May 11, 2009 | Water Heaters
Water Heaters Logo
32 people viewed this question
Top Water Heaters Experts
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
