Question about Bosch Washing Machines
What does F 21 mean on Bosch Maxx washing machine please?.
SOURCE: Bosch Maxx Instruction Manual
F:16 - Doors are not properly closed. Check the doors are closed with no obstacles.
F:17 - Water is not running. Check the tap, hose and filters. Also water pressure can be low.
F:18 - Too much water remaining. Stop the drying program and start Spin program. Otherwise something is bolcking the water exit from the machine.
Posted on Jul 16, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
SOURCE: i need a manual for my maxx 6 bosch washing
Go to this link. Just downloaded one for my Maxx7
Posted on Oct 03, 2009
  • 3051 Answers
SOURCE: I have an error code
Hello there
Normally this is a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to drain the water, from the pump then unscrew the large drain cover and remove the blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II in the top and setting the machine to 'drain'. it should beging to drain
Posted on Mar 07, 2011
  • 59 Answers
SOURCE: Error code F18 for Bosch Maxx 7 Silence washing
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly.
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
Posted on Jun 04, 2011
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
Feb 22, 2015 | Bosch Washing Machines
Washing machine won't drain
Bosch maxx 5 washing machine will not drain This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 19, 2012 | Washing Machines
Washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Mar 28, 2010 | Bosch Washing Machines
Bosch Maxx Washing machine WFL2260
On most washers, this usually means, end of prog, and you should be able to remove washing.
plz rate my comments.
Jan 21, 2009 | Bosch Washing Machines
I have a bosch maxx 7 washing machine the manel is in turkish it has come up saying f21 what dose this mean
From the user manual in English:
F:21 - Motor fault. Call customer service!
Apr 04, 2008 | Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
