Question about The Health & Beauty
My meter keeps registering E6. What does this mean? The little blood drop No longer appears. I have used it about 10 times with no trouble
5 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: My Magnum 257 10 Meter radio will not transmit in any mode.
try this page
http://www.cbtricks.com/radios/rflimited/magnum_257/index.htm
Posted on Mar 24, 2009
  • 77 Answers
SOURCE: CO meter is registering 7ppm within 5 to 10 minutes.
Ok. Your not exhausting fast enough. Check your exhaust pipe to see if it tightly connected. Next check your roof to see if the exhaust is not blocked. If all those check out. Your heat exchanger is probably cracked or one of your burners is totally dirty...good luck. If your a novice, it would be best to contact a professional.
Posted on Apr 17, 2009
SOURCE: Ref. Innovage model hl 168J Blood Pressure
Innovage model hl 168J Blood Pressure Monitor. Problem: after the pressure build up and the meter starts dropping it goes to the Diastolic reading then records error. I notice the drop is very rapid. On other monitors I have used the drop is much slowe
Posted on Jul 25, 2010
rohdd
  • 293 Answers
SOURCE: What does the E2 & E6 error messages mean on my Welby wrist blood pressure monitor mean?
Here are all the error code and their solutions
Error -- Possible causes Solutions
Display is blank
The batteries are dead. Replace both batteries with new
1.5 V R03/LR03/AAA batteries.
E 1 The cuff is not worn correctly.
Make sure cuff is worn properly and take a new
measurement
E 2 You moved while a measurement was being taken.
Sit still and take a new measurement.
E 3 The cuff is not attached correctly.
Fit the cuff correctly and take a new measurement.
E 4 An error has occurred in the measurement
Take a new measurement.
E 5 Cuff pressure above 300 mmHg
Check the fitting of the cuff (make cuff smaller) and take a new measurement.
E 6 Batteries are too weak
Replace both batteries with new 1.5 V R03/LR03/AAA batteries.
Hope this help you out. J
Posted on Jun 06, 2015
Accu chek blood glucose meter error 3 and error 6
E3 is the following
Your blood glucose may be extremely high or a meter or a test strip error has occurred.
  • If your test result matches how you feel, contact your healthcare professional immediately.
  • If your test result does not match how you feel, repeat the blood glucose test.
    • If the E-3 code still appears for your blood glucose test, your blood glucose result may be extremely high and above the system's reading range. Contact your healthcare professional immediately.
    • If the second test result does not match how you feel, perform a control test with the control solution and a new test strip.
      • If the control result is within the acceptable range, review the proper testing procedure and repeat the blood glucose test with a new test strip.
    E6 is the following
    • Blood or control solution was applied to the test strip before the flashing drop symbol appeared on the display. Discard the test strip and repeat the blood glucose or control test.
https://www.accu-chek.ca/en/meter-systems/aviva/support-error-screens
Feb 13, 2018 | Accu Chek Health & Beauty
REASONS FOR FLASHING BLOOD DROP SYMPBOL ON CHOLESTEROL METER WHILST STRIP WAS COVERED CORRECTLY WITH BLOOD
I use an Abbott Precision Xtra glucose / ketone tester, that sound similar to yours. On mine, you do not place a drop of blood ON the strip, you place the end of the strip in the drop of blood. There is a very narrow channel that then sucks up the blood by capillary action, and in the case of my tester, it beeps to acknowledge when it has enough.
On the colored side of my strips you can see the blood rise in the opening. After the beep the symbols change to a countdown while the meter does its work
I hope this will gice you at least one thing to try and observe the results of.
It is possible you had a bad strip. It does not happen often, but it does occur from time to time.
Good luck
John
Sep 17, 2016 | Health & Beauty
What is the meaning of an e-6 error code?
E6 - Circuit temperature is high. Internal circuitry is too hot to work. Wait for a few minutes to let it cool down. It may also be a result of malfunctioning fan, which fails in cooling down the internal circuit and device. Blocked air vent also causes this error. Remove any blockage and let the device cool for some time. If the problem persists, call for service.
Jun 07, 2015 | Advocate Redi-Code Duo Talking Glucose...
What does the error code E04 mean?
get a new meter if it doesnt work,they are discontinued and no info about error codes is out there
May 26, 2015 | Arkray USA Pocketchem Ez Blood Glucose...
The meter says E 5 on it what does this mean ?
Cant remember exactly but i think that is probable blood incorrectly put onto test strip, probably before meter is ready. You have to wait for the little drop of blood to appear on the display.
Mar 15, 2015 | Accu Check Aviva Plus Blood Glucose...
Why inconsistent results
Not sure but try doing two tests using different blood samples taken at same time. Note that there is always a small difference in sample results
Jun 06, 2014 | Bayer Contour Next EZ Glucose Meter Kit...
What are the error codes for Accu-Check Glucometers
E5 codekey expired which means that the test strips or out of date and no longer any good. You get a new codekey with a new can of test strips. A pain, I know.
E1 Re Insert test strip
E2 Incorrect code key
E3 Extremely high reading
E4 Not enough blood on test strip
E6 Control Solution too soon?
E7 Electronic error
E8 Temperature too high
E9 Change Battery.
May 13, 2014 | Accu Chek ACCU-CHEK Aviva Meter
ELECTROLUX EWIA12F3MS ERRORS
An E3 Error Code means the meter is sensing that blood has already been applied to
the test strip (or the strip has already been used).
What to do: Please make sure you see the flashing blood drop on the display before
adding the blood sample. Ensure that you are using a clean, new strip each time you
perform a test.
Jul 31, 2012 | Electrolux Washing Machines
I am trying to regerister my one touch ultra mini meter.Having trouble.
Catbird. you can register it one of two ways: at the following link https://www.onetouchdiabetes.com/product-registration Or you can also call Life First One Touch 800-227-8862.
Hope this helps you to register you Blood Glucose Meter.
Please let me know.
Apr 20, 2011 | One Touch Health & Beauty
Ref. Innovage model hl 168J Blood Pressure Monitor. Problem: after the pressure build up and the meter starts dropping it goes to the Diastolic reading then records error. I notice the drop is very rapid....
Jun 24, 2010 | Health & Beauty
Health & Beauty Logo
55 people viewed this question
Top The Health & Beauty Experts
Dave Jacobs
Dave Jacobs
Level 1 Expert
Ajika coates
Ajika coates
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
