Question about Sanyo Televison & Video
Sanyo Plasma Flatscreen TV MODEL-DP50741 SERIAL-Bl240940020074 Pressing the power button the indicator comes on but then I hear a CLICK CLICK no picture, nothing.
    Top Expert:
  • Sanyo Master
  • 43,901 Answers
The power supply may have failed
Posted on May 11, 2017
My LG Plasma 50PK550 doesn't show a picture when I push the power button. It will also shut off when I push either the Input or channel buttons.
Main digital board fault. Check and replace the main digital board. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 27, 2017 | LG 50PK550 50 HDTV Plasma TV
Sanyo 50 tv DP50741 speakers quit working
Make sure your audio setup hasn't changed. You can select where the audio goes in setup. If everything is correct, then the main board needs to be replaced. You can get it here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 05, 2016 | Sanyo Dp50741
Sanyo DP50741 50" Plasma TV - After a power failure audio no longer works on any input however video is fine. What is the likely issue/component?
Are you speaking of audio through the TV speakers or through your sound system? If through your TV speakers , I would go into menu and make sure speakers are set to ON or TV. Settings can sometimes be reset or changed due to spikes or surges. Recheck all settings to eliminate the obvious. If everything is fine then it's possible an electronic component such as an IC is blown. This would not be very expensive to fix. Hope this helps.
Oct 01, 2015 | Sanyo Televison & Video
Led blinking red on a sanyo dp50842
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 05, 2013 | Sanyo Dp50741
MY SANYO DP50741 POWER BOARD?
i would check to see if the stand by supplies are on the power board and then check to see if the on supply comes up briefly when power is pressed it could be the power board or main board testing the supplies will narrow down which board you need.
Aug 23, 2012 | Sanyo Dp50741
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
My sanyo plasma flat screen tv will not come on.
For what it's worth, you can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. I uploaded it here when I had some issues with this TV last year. The solution almost always seems to be to replace the Power Board and the Upper and Lower Y Buffers. The parts and costs (from Sanyo in July 2009) are listed below (NOTE: Sanyo will not ship these parts to anyone but a repair shop):
1. V4 Y-Main (Y-Sustain) Circuit Board (Part # LJ92-01200A, Alt Part # LJ41-02759A) - USD $139.00
2. Upper Y-Buffer Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3. Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD $64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for parts to USD $277.50. From my research, a shop would probably charge between USD $500 and $700 to do this repair. FYI - there is a class action lawsuit pending against Sanyo for this issue. The V4 Y-Main (Y-Sustain) Circuit Boards fail VERY frequently in this TV due to overheating. Hope this helps.
May 20, 2010 | Sanyo DP42746 42 in. Plasma Television
Code for HP Plasma Flatscreen
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3605
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Jan 13, 2008 | One For All URC-3605 Remote Control
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
