Question about Fanstel Lands Phones
Where can I get an Amplified Fanstel 150 or Amplified Fanstel 250 repaired. They get static, the volume fades, the dial tone rumbles, people on the other end breakup or they say I'm breaking up.
  • 4 Answers
SOURCE: Can't hear caller or dial-tone --Extremely faint but volume doesn' t help
the phone sux
Posted on Aug 14, 2007
  • 12 Answers
SOURCE: Fax dial tone volume
Hi!
If there an kind of button of volume then u can...
otherwise u can't..
Amit
Posted on Feb 20, 2009
  • 32 Answers
SOURCE: Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
Posted on Apr 28, 2009
JackHeath
  • 1049 Answers
SOURCE: Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
Posted on Oct 01, 2009
cnavarro
  • 2460 Answers
SOURCE: Just plugged caller id box in to panasonic kxt7420
There is no such thing as correctly plugging an analog caller ID box into a digital phone line.
CID display comes from a TD-193 card mounted in the Key Service Unit and it only displays on Panasonic system display phones designed to work on a TD system. The only system that passes CID through to stations is a TA-824 and certain models of TDA-s that have special analog extension cards.
You can use the analog box, but you have to bring the line from in front of the system to the CID box.
Carl
Posted on Nov 11, 2009
CL82309 static no dial tone
Line issue - contact your service provider for relief.
Sep 10, 2017 | AT&T CL82309 - Cordless Phone
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
Your HP all-in-one provides three levels for adjusting the ring and speaker volume.
The ring volume is the volume of the phone rings. The speaker volume is the level of
everything else, such as the dial tones, fax tones, and button press beeps. The default
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Fanstel ST-250
Fanstel sent me the user guide.
Jan 11, 2010 | Fanstel ST118B Corded Phone
None of our faxes are going out and we receive error number 87
set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
Dec 10, 2009 | Office Equipment & Supplies
Hi!
otherwise u can't..
Amit
Feb 20, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Headset has static
Oct 24, 2008 | Plantronics CS70 Wireless Headset
Dial tone
my phone has no dial tone and when you call the phone it has a busy signal. There is no static just sounds like it is not hung up.
Sep 23, 2008 | Panasonic KX-TG1033S Cordless Phone
Need help with my new amplified answering telephone.
To dial a number that is stored in memory simply click the letter that corisponds with the name of the person you want to call for example if the name is listed in the phone as John you are going to press the five key to quickly jump down the list to the "J" section. In terms of turning up the volume should be listed under sound options, or most new phones have up and down buttons located somewhere that should turn up the ring tone volume also.
Good luck and I hope this helps!
Chris
Feb 25, 2008 | Lands Phones
Lands Phones Logo
Top Fanstel Lands Phones Experts
ray gallant
shuyumeng
shuyumeng
Are you a Fanstel Lands Phone Expert? Answer questions, earn points and help others
