Question about The Health & Beauty
My meter keeps reading E5 the little blood drop does not appear
2 Suggested Answers
SOURCE: Ref. Innovage model hl 168J Blood Pressure
Innovage model hl 168J Blood Pressure Monitor. Problem: after the pressure build up and the meter starts dropping it goes to the Diastolic reading then records error. I notice the drop is very rapid. On other monitors I have used the drop is much slowe
Posted on Jul 25, 2010
Blood pressure 132/52
That is a little low for a female, but not alarmingly so. In fact some doctors will only consider that a serious problem if there are other symptoms. Also, a spot reading does not say much by itself, it is more informative to have readings at different times over a period.
You should consult a doctor, who will check for anything more serious that may be there, and who can advise you whether to purchase a blood pressure meter you can use yourself. I have one, and it has been most helpful as it turned out I did have hypertension.
Nov 13, 2016 | Health & Beauty
REASONS FOR FLASHING BLOOD DROP SYMPBOL ON CHOLESTEROL METER WHILST STRIP WAS COVERED CORRECTLY WITH BLOOD
I use an Abbott Precision Xtra glucose / ketone tester, that sound similar to yours. On mine, you do not place a drop of blood ON the strip, you place the end of the strip in the drop of blood. There is a very narrow channel that then sucks up the blood by capillary action, and in the case of my tester, it beeps to acknowledge when it has enough.
On the colored side of my strips you can see the blood rise in the opening. After the beep the symbols change to a countdown while the meter does its work
I hope this will gice you at least one thing to try and observe the results of.
It is possible you had a bad strip. It does not happen often, but it does occur from time to time.
Good luck
John
Sep 17, 2016 | Health & Beauty
The meter says E 5 on it what does this mean ?
Cant remember exactly but i think that is probable blood incorrectly put onto test strip, probably before meter is ready. You have to wait for the little drop of blood to appear on the display.
Mar 15, 2015 | Accu Check Aviva Plus Blood Glucose...
Why inconsistent results
Not sure but try doing two tests using different blood samples taken at same time. Note that there is always a small difference in sample results
Jun 06, 2014 | Bayer Contour Next EZ Glucose Meter Kit...
What are the error codes for Accu-Check Glucometers
E5 codekey expired which means that the test strips or out of date and no longer any good. You get a new codekey with a new can of test strips. A pain, I know.
E1 Re Insert test strip
E2 Incorrect code key
E3 Extremely high reading
E4 Not enough blood on test strip
E6 Control Solution too soon?
E7 Electronic error
E8 Temperature too high
E9 Change Battery.
May 13, 2014 | Accu Chek ACCU-CHEK Aviva Meter
Whats E-5 and E-7
E5 is blood applied too soon, and e7 is the test strip being faulty, used or not recognised.
Apr 25, 2014 | Medline Abbott Diabetes Care Glucose...
E-5 error code
  • Blood was applied to the test strip too soon. Slide and release buttonicon.gif to turn off the meter and release the test strip, then turn on the meter again. Repeat the test, waiting for the flashing test strip and blood drop symbol before touching blood or control solution to the end of the test strip.
  • The test strip was bent before the test started. Repeat the test with a new test strip.
  • There is moisture in the meter. Slide and release buttonicon.gifto turn off the meter. Let the meter dry at room temperature.
Apr 03, 2014 | Accu Chek Compact Plus Blood Glucose Meter
I have a blood pressure sphygmomanometer, how do you take a blood pressure reading and what is normal?
Much easier to go to a store, like Walgreens and get an inexpensive ( like 15 dollars) automatic wrist cuff blood pressure monitor, that will give you accurate and quick readings of your heart rate, and blood pressure, systolic and diastolic, automatically.
Apr 03, 2011 | Walgreens Health & Beauty
My husband took his blood pressure and an E appeared for Sys reading. We could not get it to operate correctly. Why?
E appeared because the monitor was not able to read his blood pressure. I have the same problem myself if I take my blood pressure after sitting down for a while because my pulse rate is 40 beats per minute and the monitor is set to expect a higher reading. If his pulse rate is too low the monitor thinks it's not reading it properly.
It could also be unable to read his blood pressure because the sensor was not pressed against his pulse. Try moving it around a little. Also it's a good idea to check the monitor on a second person as there could be a fault in the monitor itself.
I hope this helps.
Feb 25, 2011 | Health & Beauty
Ref. Innovage model hl 168J Blood Pressure Monitor. Problem: after the pressure build up and the meter starts dropping it goes to the Diastolic reading then records error. I notice the drop is very rapid....
Jun 24, 2010 | Health & Beauty
Health & Beauty Logo
23 people viewed this question
Top The Health & Beauty Experts
Robert
Gene
D. E. Hev
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
