Question about Humidifiers
My unit shuts the mist offafter 5 sec. - Humidifiers
My Sharper Image cool mist humidifier is not putting out any mist. I am wondering if it needs something cleaned or replaced and, if so, what needs to be done.
If this unit is an ultrasonic mist device, the mist element could be defective. They should be quiet, but still purr along and provide ma mist. The best bet it to contact the manufacturer and if under warranty, replace the system.
Jan 12, 2018 | Sharper Image Humidifiers
I have the HD15 how do you clean it latly everything is covered in a chalky mist in the room?
If you are not TOTALLY SATISFIED... and that has
the SHARPER IMAGE price tag...
(in y opinion... I would return it to SHARPER IMAGE
and us the REFUND to buy 3 to 5 equivalent units ...
(like HoMedics) for a whole lot LESS...!!
(in my opinion)).
More units... less WATER spritzing around =
I sincerely believe... the "chalky" you speak of is
merely a product of the CALCIUM level in your
water... and a mist type of humidifier. Nothing
wrong with your humidifier (follow owner manual
cleaning instructions) BUT what you see is normal
Sharper Image EV HD15 Instruction Manual Page 3
THE VISIBLE "mist" Your humidifier puts out are
solid water drops... It WILL mark whatever it
lands on...
I think there ARE things you could try...
Obviously turning down the humidifier to
merely moist... rather than SPRITZING water
on everything (solid/visible).
Spread the load between multiple machines
(as described above)
Perhaps...filtered water might help
Dietary CALCIUM is a very good thing... and humidity
is much more warm and comfortable... but the combination
is going to give you those SAME results...
But at those SHARPER IMAGE prices I would
Carnac the Magnificent
Jan 11, 2018 | Humidifiers
Sonic breathe does not mist?
Find out where the mist is supposed to escape from inside the unit. Clear the airway.
Nov 30, 2014 | WhateverWorks Bell And Howell Sonic...
It has stopped working. How do I clean it. Can the element be washed with soap?
Best way to clean it is with vinegar, it will break up the mineral deposits I'm sure the element has on it. If it is like mine the element is covered in white scale, and has stopped working. May not be worth the effort though, my element is now completely clean but the unit still auto-shuts off after about 5 min.
Mar 09, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
Hello! please advise what will happen if unit is left running & is out of water?
If the float valve in the water tank is not working properly, by shutting off the unit when it's empty, Leaving it running will probably burn up the pump motor.
Feb 16, 2011 | Sunbeam Health at Home Warm Mist...
No mist!
unfortunately on a cool mist unit the mist shouldn't show up. on most units that's what it does. the warm mist units show the mist.. the best way to tell is if you put your hand over the spout that the mist is suppose to come out of for about 2 minutes and you pull it away and it feel clammy then it's working. if your hand is still dry please let me know and i'll see what else i can do for you.
Feb 26, 2009 | Holmes Products HM500-UC 1 Gallon...
Humidifier doesn't stop
I had the same problem if you dissasemble the unit you will probably find a capacitor between two blue wires has blown out
Mar 30, 2008 | Holmes Products Cool Mist HM3500...
Honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Humidifiers Logo
Top Humidifiers Experts
Paul Carew
Are you a Humidifier Expert? Answer questions, earn points and help others
