Question about Proscan Televison & Video
My proscan tv 39 inch PLDED3992A WILL NOT POWER ON AT ALL IS THERE A RESET BUTTON.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 110 Answers
Try plugging the TV into another known good outlet. If there is no change unplug the TV for 30 minutes to 1 hour. Plug it in and try to turn the TV on again. If you have the same result, you have a bad main board that needs to be replaced. If its under warranty have it repaired or exchanged. If your warranty has expired take it to your local TV repair shop. Hope this helps.
Posted on May 11, 2017
My proscan plded3992a-c is flickering
Flickering can be adjusted. To some rare cases, the SMPS [Power] board might need replacement. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 06, 2017 | Proscan Televison & Video
Our Proscan TV was working just fine then suddenly just lost power, there is power in the cord but the light won't turn on, is there a reeset button or fuse?
No the TV has failed. most likely the main PCB has failed or is shorted. To repair this will be close to the cost of a new TV at current prices.
Aug 19, 2016 | Proscan Televison & Video
I have a Proscan plded3992a . When the TV cuts on you can see and hear everything, currently via hdmi. The screen however is dim. Still visible and blinks steadily to normal brightness.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 15, 2016 | Proscan Televison & Video
Pc hdmi no sound
some televisions require a seperate audio feed from the HDMI cable to hook up audio. if you have the cables for this i would try that first. normally ends up having to go thru an AV connection
Jan 16, 2014 | Proscan Televison & Video
I need a remote code for Proscan PLDED3992A to use with Xfinity Cable
There's now way the ir files could get from Comcast into your remote. Without a upload. So yes.
Dec 28, 2012 | Televison & Video
Proscan 32LA30Q won't power on
It appears to be a 32 inch.
Some questions:
Does power light come on and if so what color when set is off?
Were you having any problem before where you had to turn set on several times to get it to come on and stay on?
I am here to help you.
Mar 14, 2012 | Proscan 32LA30Q Television
I have a Proscan 62 inch ,rear projection TV, we plugged it in after moving it in (came strapped down on a flat deck truck) driver said it was a bit of a rough ride........it makes a small sound when...
Your problem is most likely in the main power supply or possibly in the sweep power supply. Without the know how and a service manual, you could turn a minor problem into a mojor headach.. LOL Play it safe and invest in a pro to assist you in this repair. The 'rough' ride might have loosen some connections.
Jun 08, 2011 | Proscan PS52800 52" Rear Projection...
Tv will not stay on Proscan PS52690
power supply probably needs to be rebuilt, vertical IC some filters,probably a couple of transistors. best to have an experienced tech do it for you.
Aug 30, 2009 | Proscan PS52690 52" Rear Projection...
The screen turns on hen off
Just try to reset;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Sep 14, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Televison & Video Logo
219 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
