M
It will momentarily freeze then beep
2 Suggested Answers
emissionwiz
  • 80270 Answers
SOURCE: MMy mouse will sometimes move to corner of screen and beep. What might be causing this?
I would try replacing the mouse first, you can buy generic ones on eBay real cheap.
Posted on May 11, 2017
May 11, 2017 | Computers & Internet
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
The cursor sticks sometimes when you move it across the screen. sometimes it want move. sometimes when you drag a file to put somewhere else, the cursor want release
replace batteries they get weak and cause mouse to act strange
replace mouse
replace mouse pad, make sure you use mouse pad
clean led light
clean mirror
I got a cheap replacement plug-in led mouse for under 9 bucks Walmart
Nov 27, 2010 | Logitech Cordless Mouse
My blue nipple mouse is screwing up Toshiba Satellite 6100 Mouse i in the middle of the keyboard works rarely but sometimes moves cursor to upper right or lower left corner of screen & then it...
Sounds like the keyboard has gone bad (the mouse and the keyboard are integrated into one unit). Replace it. Cheapest source of these parts will be eBay.
Sep 16, 2010 | Toshiba C99704 Mouse
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
When I move the mouse off the side of the screen
Try changing the screen resolution of your screen
Aug 19, 2009 | Apple Computers & Internet
Dell Dimension 8400 - screen goes black or just freezes, no mouse or keyboard input works. Power down and then power back up works fine for about 10 mins then same problem.
Does the computer emit any beeps? If so, how many beeps?
One quick loud BEEP, at start up means that all is loading OK. If you get more than one BEEP sound, than you could have Memory ( RAM ) that is, or has failed. Sometimes, if one of the internal fans has failed or is failing, a computer will start up, and than shut itsself down again. Look for any error messages that may come across the screen. Get on another computer, and search for "computer beep codes". If you have the original manual that came with the computer, sometimes it will list beep codes in it. As it has been pointed out, it could be the hard drive also, check the beep codes, that is a good place to start.
Jun 18, 2009 | Dell Dimension 8400 PC Desktop
Mouse doesn't alays work.
check the hard drive for any problems and re-install the drivers for the mouse
Nov 16, 2008 | HP Computers & Internet
.the mouse moves randomly across
If mouse is moving randomly across the screen then you may have to change the mouse or the mouse pad. If system freezes automatically that is your software problem. Please install a fresh copy of windows xp or vista whatever. Hopefully it should work . thank you.......
Sep 12, 2008 | Computers & Internet
Wireless mouse?
Try disabling the mousepad on the laptop. sometimes this is what causes the problem. Another reason might be the mouse batteries. If they are running low you might experience problems like that.
Apr 18, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
