Do you need multiple sticks for multiple tv's
  • Televison & ... Master
  • 1,830 Answers
Yes. I believe you do need one for each TV.
Posted on May 11, 2017
Codes to upgrade hisense40h3e to a smart tv
There is no code to turn the Hisense 40H3E into a smart TV. This TV doesn't have the network LAN or WI-FI hardware or software. You can only add network streaming by connecting a streaming stick (Roku, Fire, etc.), streaming box (similar items) or use a computer. Most streaming devices connect to the HDMI port; you may need an HDMI switch to share the TV with multiple devices.
Note: the USB port on this TV may not supply sufficient power for some streaming devices. You may need to connect them to an USB power supply to a standard outlet.
I hope this helps.
(the 40H3E does support viewing files from a USB flash drive - see the manual for the list. I found the manual on Manuals Lib here: https://www.manualslib.com/manual/1053975/Hisense-40h3e.html . )
Feb 18, 2018 | Televison & Video
I downloaded kodi on my FireStick but it won't install it, how can i fix it
Hey, there are couple of ways to download as well as installing Kodi on Firestick. I am not sure which method you used to download Kodi. I would suggest you download Kodi using ES File Explorer and then it will show install button as soon as download completes.
You can also check this guide - https://www.firesticktricks.com/install-kodi-on-fire-stick.html
If any further issues, please let me know.
Mar 06, 2017 | Televison & Video
Roku stick dosent do anything. ...? Plugged into hdmi slot on tv and also plugged in power cord to roku and nothing pops up on my tv...? Iv tryed to reset but dose nothing. ... help???
Did you change the TV input setting on your TV to the correct HDMI input? Most Televisions will take a few seconds to scan the input before displaying any image. Most newer televisions have multiple HDMI inputs, and you might need to select each one, wait several seconds to see if there's a signal, and then move on to the next input, until you find which HDMI input has the Roku start screen signal.
Dec 09, 2014 | Televison & Video
Acer x3300 desktop does not start
It could be a number of things. I would start with RAM or Motherboard. RAM is easy. If you have multiple sticks. Pull them all out and place them back in. If that is a no go and you have multiple, Pull all the sticks and put one in at a time. If it boots with one stick then you have a bad RAM stick. With all of that said, I would worry that it is motherboard since it won't take you to the BIOS screen.
Jan 17, 2013 | Acer Computers & Internet
Continous beep sound while booting my hpdv6000
This could be caused by a few things.
1) The easiest thing to try would be to your cmos battery. If the cmos battery is dead this could cause the continuous beeping. Replacing the battery would fix this.
2) The continuous beeping could mean that you have bad ram. If you have multiple sticks of ram in your pc try putting in just one stick at a time. If the computer boots just one of the sticks of ram then you have found your problem.
3) Lastly this could be caused by a bad processor or the entire motherboard.
Mar 03, 2011 | HP Pavilion dv6000z Notebook
My compaq persario sr1000 power is on the fan is on. but it beeps with a short beep and keep on. beeps pause and beeps again all with the power on but no picture on the moniter
The beeping you are hearing is a beep code. Since their is no visual image a specific series of beeps is played and repeated to help pinpoint the problem. The beep you are describing, and it is hard for me to know for sure without hearing it is, sounds like a problem with your RAM.
First, try reseating the RAM. If you have multiple sticks of RAM remove them and reinsert them. To remove the RAM, push the tabs on both ends down and remove the stick of RAM.
Reinstall them by pushing the RAM firmly into the slot until the tabs click in place.
Try booting up again. If the same beep happens try removing all of the RAM except for 1 stick (if you have multiple sticks).
If you do not have multiple sticks, you may want purchase or borrow a stick of RAM to test your machine with to determine if your RAM is faulty.
Please let me know if I can further assist you.
Regards,
KYTechnology
Mar 01, 2011 | HP Compaq Presario SR1430NX (PS566AA) PC...
Need to erase memory stick all photo's I have a sony cyber-shot DSC-H1 camera with about 150 photo's on the stick and want to erase all
Please format the memory stick using the formatting tool to delete all the contents of the memory stick. This camera does not have the option to select multiple images and then delete them.
Oct 18, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
When i fax multiple sheets, they stick together
The separator pad is probably toast.It is a little white or gray rubber pad on the scanner assy.If it is intact, clean it .If not it must be replaced
Mar 24, 2009 | HP 1050 Plain Paper Inkjet Fax
Televison & Video Logo
Top Televison & Video Experts
