Question about Home
Why do I have to hold the handle down to get a complete flush? The pipes are all new from toilet to sewer. The toilet is 1 year old
    Top Expert:
  • Home Master
  • 44,896 Answers
The flapper has to be held wide open to allow sufficient volume of water to flush thoroughly.
Posted on May 11, 2017
  • 659 Answers
SOURCE: Holding down the toilet handle till flushing complete.
No you just need a new flapper for your flush valve. Its just a 2 minute job.
Posted on Apr 01, 2009
Malcg
  • 32 Answers
SOURCE: Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Posted on Aug 16, 2009
SOURCE: Our new Toto Drake toilet is experiencing some
We invited Roto Rooter out and he had it snaked out in about 2 minutes flat! No more problems for now. I think we need to purchase one of those tools!
Posted on Oct 06, 2009
  • 15148 Answers
SOURCE: Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
Posted on Apr 26, 2010
  • 15148 Answers
SOURCE: HAve to hold the flush handle down for several
change and or adjust the flapper valve if the chain is to long flapper wont stay open long enough for the water to drain into the bowl
Posted on May 31, 2010
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
How do I get lime out of the sewer pipe servicing a toilet?
lime will react with an acid or caustic soda( sodium hydroxide) Talk with a plumber to ensure that any heavy solvent will not harm the pipes first. May be a toilet snake used by plumbers will scrape away the lime allowing it to be flushed to t\he main syatem
Oct 09, 2014 | Home
Water ridge toilet manual
Thus if the tank is continuing to drain down through the bowl into the sewer line, the rubber flapper is not seating properly with the flush. These become worn and torn and are easily replaced. Or, even with a new one installed, sometimes they are not adjusted properly to create the appropriate balance between play and pull. Play being the upward connection to the flush handle and pull being the downward draw with the gravity flow of the water. Too much play it won't actually flush or lift properly. Too much pull it does not seat tightly or won't lift up long enough to allow enough water to flow through to flush the toilet...as engineered by the geniuses who designed the toilet. A simple adjustment of the chain links attaching the flapper to the flush handle and perhaps a side to side turn of the cuff so the flapper is aligned to seat properly as it drops should be sufficient. And test, test, test, test, and test again until you're absolutely sure you've got it adjusted correctly. One or two flushes is not sufficient!
Dec 08, 2013 | Plumbing
I have just remodeled a old condo with new toilets and I am getting a strong gas smell. How can I get rid of it. I am in Thailand and the building is 22 years old.
jajoy,
Did you connect the sanitary pipe stack to the sewer line that takes away the flushed effluent? Check to see that the pipe is connected, not leaking sewer gas, not plugged up with an animal carcass, and that the pipe extends through your roof three feet past the roof line (keeps smell out of house).
Nov 29, 2010 | Air Purifiers
Apr 26, 2010 | American Standard Colony 2388.012.222...
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
My toilet is a kohler low profile. There is not a
Hacked off the old seat? You mean the closet flange that connects to the sewer pipe?
That's the part that has the bolts. They go up through the toilet base.
If you have just a straight sewer pipe now, you can connect a new closet flange to it.
1.Hardware stores sell a rubber sleeve. This sleeve fits over the cast iron, or copper, or plastic PVC pipe, and the new closet flange has a stem that fits down in the sleeve. There are two large hose clamps, that come with this rubber sleeve.
The rubber sleeve is an adapter. It adapts the 4 inch sewer pipe, down to the 3 inch stem on the closet flange. (Toilets are known as a 'Water Closet', hence the flange that the toilet bolts to, is a 'Closet Flange')
Whatever size of rubber sleeve you need to adapt two pipes together, they have it.
The new closet flange is made of PVC plastic.
(Poly Vinyl Chloride)
The flange itself is about 1/2 inch thick, and has provisions for bolts. (Use Toilet Bolts, and nuts)
Be sure the closet flange sits flush to the floor. The 1/2 inch thick rim of the flange, sits on top of the floor. The flange is then screwed to the floor with countersink head screws. The slots allow the bolts to just slip in.
IF, the flange Does Not sit level on the floor, and the area for the toilet base is not level, you need to make a flat, level surface!
Do Not half step this, or you'll have a toilet leak from now until the time you fix the floor!
Would appreciate it if you would rate my solution. If you have additional questions, state them by clicking on Additional Comments.
Jul 17, 2009 | Kohler Santa Rosa K-3323-0 White Compact...
Apr 01, 2009 | Kohler Home
Home Logo
49 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
