Question about Viking VGSC366-6B Gas Kitchen Range
Viking range top 2 burners won't light
I have a 48" Viking rangetop, the left 2 burners light ok, the simmer/griddle in the center lights ok, the right 2 burners won't light. I hear the clicking on left side of the rangetop when I try to light them, then smell gas, but they don't light. What is wrong?
  • 2 more comments
  • Anonymous Jun 02, 2008
    I have the same problem. 4 of the 6 burners will not light on my viking range. Can you help?
  • Anonymous Nov 24, 2008
    Have a viking 4 burner and only the left burners work. Left rear burner clicks when right burners are turned on and right burners never turn on.
  • ritchiew Nov 30, 2008
    Two burners on my 4-burner VGIC 365-4GSS won't light by their pilot lighters. Light fine with a match. When our condominium opened five years ago, Viking speculated that it was low gas pressure (no so, all other gas appliances are fine). My wife refuses to even try and use the two burners now. The other two are stubborn but will work on first, second or third try. Thank goodness for the old reliable match.
  • caseythedog Apr 22, 2009
    I am down to 1 burner. The right burners won't even click to ignite anymore. I would love to fix this problem.
  • 3,037 Answers
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through Viking themselves whether you want them to replace it or you yourself replace it, you can get the part through them.
Posted on Apr 27, 2009
Is there a cleaning manual for my 6 burner/griddle viking range?
I have a product that I use to clean my burners and griddle with, it is made by ECOLAB and is called Greasecutter Plus. It doesn't hurt the range but it makes it look brand new, even my griddle comes completely clean. You just spray it on then let it sit for a bit then it wipes clean.
Apr 18, 2010 | Viking 48" 6 Burner, Grill Professional...
How do you access the ignitor wires for the
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range.
Apr 08, 2010 | Viking VGIC485-6G Gas Kitchen Range
Where can I locate the model number on my viking range? (48")
Mine was located to the left of the top burners. Remove the grates covering the burners, remove the 'spill' pans, lift up the surface that held the spill pans and then on the LHS you should see a plate with your units details.
Jan 20, 2010 | Viking 48" 6 Burner, Griddle Professional...
Need to replace griddle thermostat
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Apr 15, 2009 | Viking VGSC306-4B Gas Kitchen Range
Simmer plate rusted over
try using a white vinegar/water solution to wipe it off, then wash the vinegar solution off and seal with oil.
You may have to do it a few times to get the worst of the rust off.
If you get to the point of using it, to prevent it happening again,after use you need to clean it off any always finish by wipingit down with an oil soaked paper towel to seal it.
It will get discolored with use, so if you don't have one already
I would advise buying a cover, Viking make a stainless or a chopping block cover.
Jan 04, 2009 | Viking VGRC485-6 Gas Kitchen Range
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
I have a viking rangetop and the griddle's gas is not turning on the glow plug works fine but no gas seems to be coming out.
Check the amperage draw to the igniter, if it is over 3amps and no gas, first off check the valve on the manifold behind then control panel if the valve is open then check the wiring to the thermal valve if it is connected then it would appear that the thermal valve is defective.
Sep 06, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking VGSC366-6B Gas Kitchen Range Logo
2,063 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
