Question about Bush Televison & Video
Midwall unit works /cools for a while and switch off by itself,and comes on when switched on again with a remote, what is the fault with it?
Dunham bush midwall unit,model-number :WM08LHNI
    Top Expert:
  • Bush Master
  • 75,025 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on May 12, 2017
Areoaire propane centeral unit will not heat unit has a system that flashes a light to tell what problem exist. It is flashing 3 times what can I do?
You'll find the fault code list on the inside of the blower compartment cover, usually. The code typically refers to the pressure switch, which is a round disk. If it's plastic, it'll be black but if it's metal, it should be silver. You can turn the power off to the unit and pull one of the tubes from the unit itself, making sure you leave it on the switch. Placing the tube in your mouth, blow out gently and suck in like a straw. If you hear clicking noises then you know that the switch is moving internally. You can then reassemble and try again. If it doesn't work and the fault code is telling you it's the pressure switch, then it needs to be replaced.
Jan 22, 2017 | Heating & Cooling
Could be one of two things a fault on the remote itself, have you dropped it hard at sometime?
The other cause is the remote sensor on the unit itself, being faulty.
Try a cheaper universal remote, to see if that will work the unit. If it doesn't it is the unit that's faulty. If it does work the unit, you can either keep the universal or search online for a new remote. If you do that enter the model number on the remote itself. It will make it quicker to find than adding the model of the DVD unit.
Mar 18, 2015 | Televison & Video
Lg muilty system midwall unit error code c1
C1-Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace
Nov 02, 2010 | LG Art Cool LA181CNW Split System Air...
Samsung sp50l6hx stays on stand by will not come on please help !
could be the lamp, ballast, cooling fan or the power supply. can call 1-800-samsung for nearest service center.
Nov 25, 2009 | Samsung SP50L6HX 50" DLP HDTV
I purchased a 7000 BTU portable airconditioner by commercial cool for Haier. I set it up without an issue and was able to turn it on and utilize the remote control to go through all the settings. A...
There may be a master reset switch or combination of buttons to press. The Manufacturer may be able to walk you through this process. Otherwise I would simply exchange it. It sounds like it has a manufacturing problem.
Jun 16, 2008 | Heating & Cooling
Televison & Video Logo
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
