I have a unitworking in the server room,operates for a while and switch off after it operated for some time,when u switch it back on with a remote comes on again.what is the cause/fault?
  • Heating & Co... Master
  • 1,660 Answers
Are you sure it's not satisfied, therefore shutting off?
Posted on May 11, 2017
Hunter Ceiling fan remote is operating all the other ceiling fans as well
Sounds like all the dip switches are set to factory still. Easy enough to fix.
Slide open the battery compartment on the back of the remote control and remove the fan's canopy against the ceiling. Then just change the switch to a different setting but make sure that the remote and fan have the same setting. Repeat this in each room so that all the fans have a different setting to each other.
Hope this makes sense.
Aug 02, 2012 | Hunter 52" Ceiling Fan With Light And...
Unit will not turn on without the remote.
To operate the unit without having the remote .. Turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in and turn the ON/OFF Switch to ON. You should now be able to operate the controls on the unit itself. As it should have reverted back to the original factory setup settings.
Hope this helps you and thanks for choosing FixYa.
Aug 07, 2011 | Amana ACD105R 10000 BTU REMOTE/TOUCH ROOM...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Track lighting remote control similar to that of ceiling fan?
Yes, but the remote operates on the switch that turns the lights on and off. Lutron has this kind of technology and it is really cool. I have it all over my house and I don't even have to go room by room turning lights off; I just push a button from my bedroom. Along with a single remote that can be used with each switch in your house, you can program a house remote that controls the lights and ambiance of every room.
Jun 03, 2010 | Universal Remote Control Hampton Bay...
a network or networked computer is any computer that is connected to a network whether its wired or wireless or possibly even bluetooth so that it can exchange information or share services such as printers / storage etc.
Thin Client is like citrix where you can use old hardware ( computer hardware ) to connect to a server that will use the network to run the operating system ( but the operating system is on the actual server )
generally they have numerous servers in one area and you can manage everything in that one room or location.
May 09, 2009 | Computers & Internet
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Hampton bay fans
inside the remote, and inside the transmitter above the fan there are 4 tiny keys that set the frequency. set each frequency different then the remotes will only operate that fan. However if two lights r on and one off, when u turn the switch off they all go off, and when u turn it back on the same ones should come on. Then label the remotes!!!
Jun 04, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Cinego replacement factory remote control will not operate the projector
Go and buy a universal remote with button memory capability. (able to learn any remote function). That works great for me.
Apr 28, 2008 | Radio Shack Cinego D-1000 Multimedia...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
