My smart TV power stays on soon as I plug in cable box or DVD player stays on for a minute then shuts off when I disconnect everything TV stays on can you please help thank you
  • 13433 Answers
SOURCE: Cannot turn on
check for a blown fuse in the power supply area. if you got warranty that should cover the repairs if not a simple blown fuse problem.
Posted on Jul 17, 2008
circuitworld
  • 335 Answers
SOURCE: TV does not always recognize the DVD player
that's a firmware problem where your tv's firmware does not handshake with your dvd's firmware. This could be from your dvd's software being to old for your tv to understand it. HDMI (TDMS Technology) still has Alot of catching up too do with 3rd generation tv's. Alot of HDMI devices still have the first gen software loaded into them. So a tv after 2005 won't work with HDMI from 2003 (1st gen). Most tv's made after 2007 have software that's "backward compatible" so they will work with first gen HDMI.
How does your tv perform outside this problem???
Posted on Feb 11, 2009
  • 52 Answers
SOURCE: connecting new Sony DVD player to a TV, VCR, & Comcast cable box
wheres the dvd hooked up
Posted on Feb 14, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
  • 66 Answers
SOURCE: no sound from any source from speakers
check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
Posted on May 05, 2009
No power when plugged in in any socket.
Solving HDMI Problems - HOW TO GUIDES
www.hdtvsupply.com > HOW TO GUIDES
Rating: 4.7 - ‎2,086 votes
The hdmi cables carries a low DC voltage while connected. ... If so, reset it to match the native resolution of your TV or video projector (such as 720p or .... Source Device:Any Blu-ray Player, DVD Player, Gaming Console (PS3, Xbox 360), ... Power cycle:Power off / Power on equipment (At the wall socket since some LCD's ...
HDCP / HDMI Handshake Troubleshooting and Guidelines
site.hdtvsupply.com/hdcp1.html
The hdmi cables carries a low DC voltage while connected. ... Source Device = Any Blu-ray Player, DVD Player, Gaming Console (PS3, Xbox 360), Apple ... Power cycle = Power off / Power on equipment (At the wall socket since some LCD's ...
Amazon.com: Customer Reviews: Belkin Conserve Socket ...
www.amazon.com/Belkin...Socket.../B003P2UMQ2
Amazon.com, Inc.I wanted to completely turn off my subwoofer amp, blu-ray player, PS3 and .... but my Mac uses next to no power and my PC normally gets shut down after use). ... I hereby give up any and all hopes regarding Belkin support. ... I plugged her television in to the main outlet and her Wii and dvd player into two of the other ones.
[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warranty
https://docs.sony.com/release/bdps3100_bx310.pdf
Sony Corporationin this Blu-ray Disc/DVD player is harmful to eyes, do not ... be unplugged from the wall socket immediately in the event ... operating in conjunction with any other antenna or ... However, there is no ... as power-supply cord or plug is damaged,.
Jan 26, 2016 | Televison & Video
Screen freezing
Are you sure it is the TV itself and not the way the signal is received? By that, I mean check your input receiver such as satellite or cable box isn't the fault. Does it happen with a DVD or video player? The best way to do this is to disconnect all the power to the equipment. Don't just turn off or put in standby. Remove all the plugs and leave for 10 minutes then reconnect and see if that rectifies the problem. If it doesn't, then only connect and power up one piece of equipment at a time until you eliminate everything and prove it is the TV.
Jan 07, 2016 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
I turn on the cable box and the tv and about 1 minute to 4 minutes later the tv short circuits and turns off. The cable box is still on. The cable company came to change the box and the cables but it...
Sounds like there is too much voltage going into the same outlet. Please keep in mind cable boxes as well as your tv hold a higher amount of voltage then your dvd player. If your tv is plugged into the back of your cable box, unplug that and just plug it directly into the wall. If not, get a power strip and plug it in that way.
Nov 20, 2010 | Televison & Video
Onkyo receiver TX SR 605 saying no signal input from cable when everything appears to be plugged in correctly and powered on and it was working 10 minutes ago. All other connetions (Apple TV, dvd player)...
Hello, I am sorry about your issue. Please plug the cable box into a known good HDMI port on the receiver. Confirm that there are no issues with the cable or plugs. Thank you, CB
May 30, 2017 | Onkyo TX-SR605 Receiver
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    I cant get my dvd to play using my rf modulator
    instead of plugging in the rf modulator before the cable box, i plugged it in after it
    Jan 24, 2009 | GE 25GT240 25" TV
    Denon 1920 DVD Player Shuts off
    I've had the same problem on my 1920. Not knowing exactly what I was doing I disconnected some of the smaller boards (inside the player) from the main board powering on/off in between. When disconnecting the board fitted with the 5.1-out channels the player started up fine. Even after i reconnecting the board the player behaves normal again.
    Jul 09, 2008 | Televison & Video
    LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
    you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
    Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
    Televison & Video Logo
    24 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
