Question about Singer Sewing Machines
I have a singer viva create &a repair machine was working fine but needle needs to be realigned stiffness
SOURCE: My Singer 2639 Bobbin case
Hi, I used to have the same problem. I pulled the whole bobin casing out, cleaned it oiled it. When I put it back in, I made sure the actual bobin was turing the right direction so the cotton didnt snag and pull casing up.
If you havent already tried this give it a go.Its amazing how much gunk gets in there.
Posted on Sep 03, 2008
  • 323 Answers
SOURCE: Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
Posted on Apr 11, 2009
  • 136 Answers
SOURCE: Needle direction on an industrial singer machine
down
Posted on Sep 27, 2009
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
Please how do I work a zig zag pattern on my manual operated singer sewing machine
Hello, Annelien -
Unless your manually operated sewing machine has switches to realign your sewing machine needle to make zig zag stitching, as is demonstrated in this YouTube video (starting at around 6:30 minutes in the video):
https://www.fearlessmakers.com/manual-sewing-machine-works/
you cannot. Note: The machine in the video is a Necchi brand sewing machine.
Without knowing the model number of your manually operated Singer sewing machine, I cannot try to find operating instructions for it to determine if your machine has zig zag stitching potential.
Best wishes.
Jan 24, 2018 | Singer Sewing Machines
I am trying to replace monofilm panels in a windsurfing sail, using a Singer 457 zig zag sewing machine. I cannot create a good zig zag seam when the monofilm is sandwiched between two canvas layers.
Joe, you might try a larger needle than you're using. You might also want to try a larger leather needle. You machine should take needles up to a size 18.
It sounds like the needle you're using is having a problem picking up the bobbin thread, and that might solve it.
Mar 09, 2017 | Singer Sewing Machines
Needle is not catching the lope. This is singer 6212C. Needle bar has 3 marks,which one do I use no setting the needle high?
The eye of the needle should be just above the hook of the bobbin rail at it's lowest point. If you have more questions than that and need more specific help try talking to the people at the link that I attached. They are great to work with. Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Jan 31, 2015 | Singer Sewing Machines
I was sewing just fine and then the machine got sluggish and the side wheel is super stiff. I removed all lint but it's still to stiff to work.
Maybe, you need to take a screwdriver and clean out under the throat plate. Sometimes, the lint and thread builds up under there and clogs it. After you get it cleaned out, lubricate, change your needle and rethread. I hope that is all that is wrong otherwise it is a timing issue and that is not a do it yourselfer project, because you need special tools and expertise to fix it. Good luck, I hope that I helped you.
Dec 13, 2010 | Singer 7442 Mechanical Sewing Machine
Singer Esteem sewing machine. Needle works with all presser feet except my 1/4in quilt foot. It's hitting just to the side of the hole in the foot. How can I fix this? There is nothing to move the needle...
Check the needle to be sure it is not bent.
If this is not the problem, you will need to choose another foot to use until the machine can be repaired by a professional.
Feb 28, 2010 | Brother ULT2001
Old singer sewing machine (306k) motor works,belt o.k. but drive to needle is very stiff needle barely moves / peter
Apply a little singer machine oil to each of the holes along the top and in the working area next to needleplate.........rock handwheel gently and make several full rotations in each direction ......... keep at the rocking and rolling periodically over several hours if necessary....it should come good after a little patience and persistence. Do not apply too much oil, it will only make a mess. NOTE: Belt needs a little give to prevent motor overload, so do not overtighten.
Sep 08, 2009 | Sewing Machines
My machine wont do zigzag stitch
Either you have a blunt or bent needle. or the needle is in the wrong way round, or you are sewing on a fabric that creates static or the machine mat need retiming, if it is the last one email me and I will attach timing instructions drivewithken@blueyonder.co.uk
Aug 08, 2009 | Singer Sewing Machines
Stitch pattern is wrong
Here's the manual,
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Lets see if we can do some troubleshooting.
Have you checked your needle (size, for thread your using, material)
It sounds like a tension/settings issue, but could be as simple as poor thread quality. try changing the thread, and rewinding the bobbin. If using a silky material remember you need to back that up and make it stiff.
If this and a resetting of tension doesnt work,
Check your left side right side balance (pg 57)
Check page 84 on trouble shooting
Jan 27, 2009 | Singer 3116 Simple
Sewing Machines Logo
29 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
