Have unplugged for hard electrical circuit reset. TV has been playing fine will not turn on, does make some speaker noise intermittently.
  • Dawn McCray
    Dawn McCray Jun 10, 2017
    Mfgr'd : 6 / 1998 Hitachi
    Model # 60EX38B
    Serial # V8F003468
    Technicians for Troubleshooting?
    Top Expert:
  • Televison & ... Master
  • 33,359 Answers
An internal fuse may have opened or the power supply may have failed.
Posted on May 11, 2017
  • Dawn McCray
    6 / 1998 Hitachi
    Model # 60EX38B
    Serial # V8F003468
4 Suggested Answers
deanam
  • 15 Answers
SOURCE: location of reset on unit
when you disconnect it from cables, it resets. But i believe that is not the problem. Check speaker cables. I think you have problem with internal power amps. They have thermal and current protection. look for short circuits on speakers or speaker cables.
Posted on May 30, 2009
gopakumarg43
  • 73698 Answers
SOURCE: Sony Trinitron TV's is making a fuzzy noise from the TV's speakers but when played via my amp everything is fine....
Hello
The audio output IC of your TV is faulty. It should be replaced with same type and number. If there is some loose sodering on the solder terminals of this IC, this type of fault can occur too. So check this first, before replacing the IC. Ok
Posted on Nov 22, 2011
  • 26 Answers
SOURCE: Sony trinitron tv, picture works but the sound it emits is white noise (sound worked fine previously). Playing tape on a vcr has sound, revert back to tv is white noise again.
Is the tv signal originated from cable tv box? Or a antenna?
Posted on Nov 24, 2014
Testimonial: "cable tv box"
40" Element turns on/off intermittently.Now stuck on one channel. no sound/picture blank screen with channel number onscreen. remote turns tv off /on, manual buttons on tv don't work. Ideas?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Feb 01, 2017 | Element Televison & Video
TV trouble shooting
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jun 01, 2016 | Vizio Televison & Video
Sound intermittent tv
Check the speaker/s first. If found OK, check for any loose solder terminals at its audio output section circuit.
Oct 25, 2013 | Insignia NS-39L240A13
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Tvee 20 subwoofer has distinct hum noise. Any advise?
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
May 29, 2011 | Boston Acoustics TVee Model Two TV...
I have an Acoustimass 10 system with SL 2 Wireless Sound Link and Yamaha HTR-5860 receiver. The rear speakers hiss when I have the TV on but don't hiss when I play a DVD. I have checked all connections and...
when you play real DVDs?
im assuming you do
DVD quality is higher than standard TV signals and also TV signals are subject to noise from the envionment
as for DVD there is every little chance for noise because its from DVD player to speakers.
what you could try is swapping the cables that carry sound from the DVD palyer to the system with the ones that carry sound from the TV to the system
if you can
and see if that helps but i doubt that it will help
all i can say is you have to live with the noise or get a HD reciver or something along those lines
also i just read that the back speakers are wireless temporarily move the wireless speakers towards the transmitter and see if the noise stops
or if you can hard wire them temporarily and see if it helps
May 11, 2010 | Bose Acoustimass 10 II System
Popping and cracking noise from rt side speaker
You probably have a bad solder connection or an intermittent part failure in the right audio amplifier or its source circuitry. Put in a call for warranty service.
Dec 08, 2009 | RCA Televison & Video
Location of reset on unit
May 30, 2009 | Sony CDX-GT500 CD Player
Insignia PC speakers - give a weird static feedback noise
I'm going to vote for the haunted option.
Sound like you have some noise on your power lines. This can be caused from many different things. Normaly it is a motor going bad or a compressor starting up. From the AC unit or refrigerator.
See if you can correspond the noise to anything else happening in the house. Fridge starting up, AC or heat cycling on...etc.
It may be that you just have speakers and a cordless phone going bad at the same time.
It might just be Casper the friendly ghost playing tricks... ha!
Jan 23, 2009 | Insignia 2.0 Speaker System (2-Piece)
Tv turns on and off
My JVC 35 " AV 35750 toggled on/off non-stop too.
Fix for me: Unplug TV. Trace cables from on/off switch to main circuit board. I unplugged the cable at that point to eliminate the the on/off button and remote control sensor. Applied power to the TV and my TV stopped cycling on/off so I figured the problem was probably not on the main circuit board but with the push button/ remote control sensor board. I again removed power from the TV and plugged the cable back in to the main circuit board. I then applied power back to my TV to verify my symptom, but when I did this, the TV worked fine again.
Many times resetting circuit board connectors will clear electrical problems.
Jul 22, 2008 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
