The tub is loose. Seems unattached and leans to the side.
3 Suggested Answers
  • 19 Answers
SOURCE: lte5243dq6 tub broken loose
I had the exact same problem. I was able to find out that the suspension rods are prone to this problem and Whirlpool had actually replaced all of them with a new kit part # that comes with 3 new suspension rod springs and replacement instructions. The old part # is 3406201 and the new part # is W10207783. When I called Whirlpool parts and expressed disappointment over the fact that the washer/dryer combo is just over 1 year old (and thus out of warranty) and that they recognized the poor construction of the original parts by the fact that they have a new kit to replace the 'defective' ones, I convinced them to sell me the new W10207783 kit at 50% off.
So I'm in the process of replacing the rods and unfortunately, once I got everything disassembled, the instructions say to inspect the screw threads in the base. Sure enough, all the loose spring movement wore away at one or two of the base screw threads, so I now have to order a replacement base. I just gave them the same explanation as to why I should get it at 50% off, and they agreed to grant me a courtesy discount on the base. Base part # is 8577373. They have 393 of them in stock as of 2/28/09. They wouldn't comp me on shipping at all, but I wanted it shipped 2-day since I have washing machine parts all sitting out and about.
I'm anticipating that once I get the new base, I'll be able to screw in the new springs and put everything back together within an hour or so and have a good-as-new washer. I'm a big do-it-yourselfer, so this work may not be for everyone. You could probably buy the parts discounted from Whirlpool then call a service repairman to follow the instructions and do the replacement for you. But because I did it myself, my total out of pocket, for the two parts at 50% off each plus tax and 2-day shipping on each order, was about $135 (~$70 for the springs and ~$65 for the base, including tax and shipping). If you're smart, you'll order both parts at the same time to economize on shipping. Or, maybe I'll try to scan and post the disassembly instructions so you can take it apart to see if your screw threads are stripped as well before you call to order only the replacement partsthat you truly need.
The whirlpoolparts.ca website is much more user friendly for the replacement purposes as I was able to find much more info there than on the US site. Here is the parts schematic for our unit:
http://www.whirlpoolparts.ca/parts/fspShowPageDetail.php?model=LTE5243DQ6&pageNo=11&bottom=true
and a service bulletin about the replacement of our suspension springs:
http://whirlpoolparts.ca/bulletins/attachments/bulletin_544/8178766C.pdf
Tools required for this since they are not listed in the instructions:
-philips screwdriver
--adjustable wrench pliers (needed for removing the suspension nuts, but also helpful for removing the hose clips which was tricky -- slide the hose clip up and off the hose, then with both hands, twist the hose to loosen it and get it off)
--1/2" wrench
--5/16" hex driver
--old towels, moving blanket or cloth drop-cloth to protect your floors
Good idea to vacuum out all the dust and other junk when you have the base out. Also, when you remove the counterbalance spring, use a paper towel to get a good grip and also to protect everything from getting greased up since it's got grease clumps there to prevent wearing away of the metal-on-metal. Be sure not to wipe it all off since it should remain there for that purpose. Also, I found it easier to unhook the bottom part of that counterbalance spring than the top -- the instruction just says just to unhook it.
One other note is to have an extra stabilizing hand help you when taking off the suspension nuts. Once you have 2 of them off, the whole assembly becomes very unstable. When taking those nuts off, don't worry if they fall behind the suspension screws, it's actually easier to have them do that, then after taking the assembly off the suspension springs, pull out the nuts. I'm sure I'll have a hard time lowering the assembly onto the new springs and getting the nuts started at the same time, so I figure an extra hand might very well come in handy when I get to this point too.
Good luck to all in fixing this annoying problem! Once I'm done with this mess, I'll report back to let you know how it all went when all was said and done...
Posted on Feb 28, 2009
caroldon
  • 17130 Answers
SOURCE: Maytag top load washer shakes.
Seems with your observation that the tub is out of shape and so it might be wobbling when it runs. So the only option is to change the tub with a new one but the cost must be confirmed to decide between a new tub or a new washer.
If you can get a salvaged tub it will be economical.
Posted on Sep 26, 2010
Admiral washer machine tub appears loose and unattached in rrear
First of all is your machine working or not?
If it is working and it's a front loading machine. The machine drum is hanging inside the machine using strong springs that helps it to reduce vibrations during washing and spin cycle.
When machine goes into spin(dry cycle), it usually shakes a little.
Dec 08, 2014 | Admiral Washing Machines
Shakes like crazy spin
Your maytag washer tub and basket assembly sits on a base counter balanced by 6 springs. Is is possible to move the tub around by hand. The best test is to start a spin with the unit empty of cloths, allow the tub to reach speed for a few seconds, lift the lid and check the tub position after it stops, if the tub is off center with the lid opening, re center the tub and run spin again. If your tub returns to an off center stopped position you most likely will need the base kit replaced. The base kit replaces the entire bottom of the unit along with new springs, and snubber, if so packaged per your application. Maytag experienced a defective stamping dye when these bases were stamped, thus they were stamped crooked. This test is performed with the machine it's self relatively level on the floor. If the tub assy leans and favors any one direction while you are trying to center it with the lid open, you may have a rusted or broken counter spring in side the unit. Pleazer Appliance...
Apr 11, 2014 | Maytag Washing Machines
I have a Kenmore washing machine model # 11020854990 which recently had a loud banging and knocking sounds during the final spin cycle. Now I notice the drum seems to have dropped down about an inch plus...
Could be a loose basket nut, or on the bottom tub support there are a few springs that help locate the tub. One of the springs could have come off or broke.
Nov 28, 2017 | Kenmore 24032\24036 Top Load Washer
My Washer Baskets is leaning to one side when washing and spinning
Hello penpoint1959 - The tub is stabilized in the center with multiple springs which attach to the base of the washing machine and the frame of the tub. If one of the spring(s) is loose or broken, this may result in the tub being off center. Other possibilities are, the unit is not level and the load of clothing is not balance evenly in the tub. I personally first verify that the unit is level and the unit is being loaded evenly. If correct, and if I was in your position I would contacting a certified technician to move forward accurately and to assist with the repairs.
Feb 17, 2013 | Frigidaire FEX831CS Top Load Stacked...
Maytag top load washer shakes. The plastic tub seem to be the problem. I took the front off and watched it spin. The tub seems to want to lean to one side and spin out of round moving up and down. All...
Sep 26, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My kenmore elite top load washer was rinning perfect til it got dropped 8 inches during a move now the whole tub seems loose and it wont balance when the spin cycle is on Help
Your support plate under tub above gearcase was knocked out of place, lean washer back and try to adjust plate back in place were it is sitting back on the glides. This is not an easy task bu it can be done,sometimes it is best to call a repairman to do the repair so he can check if there is any more damage.
Dec 22, 2009 | Kenmore Washing Machines
Washer FTR630ASO Fridgedaire - inside tub is loose and loud
we've got this exact washer. we had a very similar sound/problem. it turn out to be the shock absorbers. easy replacement. under $100.
Oct 08, 2009 | Washing Machines
Unbalanced spin cycle
it sounds like one of the levellers is out or the bearings in the tub are shot.
Jan 21, 2009 | Kenmore Washing Machines
Washing Machines Logo
Top Washing Machines Experts
