Question about Honda Garden
Why does the Honda GCV160 motor (model GJAEA) with auto choke on my 2008 Troy-Bilt lawn mower only run at high speed?
After installing new carburetor gaskets, the mower starts very well but the engine will immediately go to high speed. I note that the tension spring on the governor lever stays tight and the throttle plate on the carburetor remains nearly wide open no matter whether the mower is running or not. This mower has no throttle control on the handlebar.
    New Friend:
  • 29 Answers
Governor spring may be in a bind or missing or even old resulting in stretching. Look at an ipl (Illustrated Parts List) to see location of spring and check on you engine. This happens if engine is exposed to to much moisture resulting in rust, weakening the spring, or upon replacing another part trapping the spring in someway due to improper reassembly.
Hope this helps.
Posted on Feb 02, 2018
    Loyalty:
    Visited the website for 30 consecutive days.
  • Honda Master
  • 1,099 Answers
Adjjust timing go to PsartsTreeRepairClinic they can help
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 62 Answers
SOURCE: Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Posted on Sep 07, 2009
  • 13 Answers
SOURCE: Troy bilt bronco
clean and lube around butterfly arm and "windvane' under engine cover.most governors are controled by air coming off finns on flywheel also check to see if you have return spring broken or missing
Posted on Mar 27, 2010
  • 61 Answers
SOURCE: When starting mower, the choke resist opening and
I'm not sure this will be of any help, however, try spraying WD40 on the choke butterfly. It may be a little sticky from varnish from old gas. Be sure the butterfly is moving freely.
Posted on May 09, 2010
Testimonial: "Thank you. I will do this. It has to help. Additionally, I put a capful of carburator cleaner in the gas tank. Perhaps the float may be sticking too."
MOTORWIZJ
  • 1383 Answers
SOURCE: engine doesn't stay running
99% ITS WATER IN THE GAS
Posted on May 21, 2010
Selfpropelled portion stopped working, replaced broken belt,have correct p/n for new belt,belt is slack ,self propelled not working
There should be 3 pulleys one on the motor on top of the blade, one on the axle for the wheels and one that goes to your cable to engage that pully and tighten the belt, take the cover off that hides the axle and pull your handle for the self propell and see if its tighting, some mowers have a little adjuster to tighten the cable on the self propell handle or even on the cable itself, did you make sure to run the belt between the guides over the blade, let me know what you find so we can further help
May 15, 2016 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Search serial # 1B288H20023
Hi Edward:
What is it that is the problem with the machine?
Mar 20, 2015 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Choke adjustment
The manual is on this link: http://engines.honda.com/parts-and-support/owners-manuals/GCV160 The manual depends on the serial number. It does not appear to have adjustable choke.
Jun 05, 2014 | Husqvarna 21" Lawn Mower with Honda GCV160...
Drive belt comes out
There is an adjustment to tighten up the drive belt tensioner pulley. You should be able too see it after you remove the safety shield. Tighten adjustment nut to snug belt.
Apr 20, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Honda gcv160 what should the spark plug gap be?
For a Model HRR2163TDA 5.5hp.(GVC 160 Honda)..it is .028 - .31 in Don't know what model you have ...would assume about the same...I am not an expert
Sep 28, 2013 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy Bilt mower w/ a Honda engine GCV160. OK, so I turned it on it's side after the last mow and the next time I tried to start it, it smoked and quit. Now the engine will not even turn over when...
Pull the spark plug and see if there is oil in the cylinder. When you turn a 4 cycle engine over or on it's side, the oil can leak into the cylinder. There may be so much oil in there that the piston won't move. When you have the plug out, clean it before you re-install. Good luck...Lee
Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower won't stay running to cut lawn
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
49 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
