Question about Coffee Makers & Espresso Machines
Err2 error code, what does this mean? - Coffee Makers & Espresso Machines
What does PSTD stand for on the remote?
Washing Machine ' FAQ ' Help & Troubleshootings ' Haier ZA
www.haier.com/za/help_and.../faq/washing_machine/
HaierQuestion : Error Code-control panel display "Err2" · Question : Error Code-control panel display "Err5" · Question : The door lock light flashes 8 times and stops .
Oct 29, 2015 | Haier Televison & Video
I followed the instructions you gave me for the ERR2 problem.. but still not working.
I have a coffe maker that is 1 week old, the model number is w10321647a, it is a cusinart make and I am unable to make coffee when I press the Brew buttion, I get an error message that is err2. I have unplugged the coffee and plugged it in a again and it is still coming up with err2 and no coffee. Please help!!
Jan 27, 2011 | KitchenAid KCM511 Coffee Maker
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Kitchen Aid coffee maker err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a few seconds.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Apr 07, 2009 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee pot won't brew coffee reads err2
If it does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Mar 13, 2009 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee maker model #kcm515 displays err2--is there anything I can do to fix this? Thank-You! Scott
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Jan 09, 2009 | KitchenAid KCM514 Coffee Maker
COFFEE MAKER READS ERR2 ????????????? HOW DO I FIX IT???
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a moment.
Aug 07, 2008 | KitchenAid Superba Architect KSCS25INSS...
Haie hw-c1460tve
Err2 means "Drainage error. water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for a blockage. If error still exists, please contact the maintenance personnel." This is what it says in the instruction manual
Feb 20, 2008 | Washing Machines
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
