Question about Tablets & eReaders
Why do the apps sometime,s come in side ways - Tablets & eReaders
  • Brett Duxbury
    Brett Duxbury May 11, 2017
    Hi mark stewart, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    How are you holding the device as it has a gyro sensor in it that senses how the tablet or mobile phone is held and will put the display the way it is held ?
How to update app on my ipad
There are two ways to do this:
1) Usually you will see the app store app with a number in the corner indicating the number of apps that need updating - if you tap that in the app store you will see an update button - tap that and it will show you all the apps that need updating.
2) Another way - would be to delete the app and then install it again. Depending on how information is saved, this way may remove saved information.
red number on app store icon
Apr 29, 2017 | Tablets & eReaders
I bought my daughter a Contixo tablet for Christmas, it connects to WiFi , but there are no apps installed or seemingly any way to log onto the internet. Any help will be greatly appreciated!
it should have an internet browser
does it have google play store .
Do you know how to use a tablet.
You may need to place finger on right hand side of screen and swipe finger to left side of screen. Apps may be on next screen
Dec 27, 2016 | Contixo Tablets & eReaders
How do I delete an app?
Find the icon for the app you want to delete, and press and hold it for a few seconds. It (and all the other icons on the screen) will start to wobble gently, and a small cross will appear in a grey circle by each. Tap the cross, then confirm you want to delete the app.
Mar 01, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Start back to level 1 on seaside escape
you can always delete the application, by either pressing the home key until you see all the apps that you have running, and then to the side of the home key you should see task manager, you can delete the app here. you can always drag the app to remove it, or you can go to settings and then data usage and application manager and delete it their. if you have to go to play store and remove or uninstall the application that way as well.
Oct 13, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I have 1400 emails on my ipad I need to delete quickly.
In mail, when you are in a specific mailbox, on the top right side of the left hand column (in portrait view) next to "inbox" press "edit". Then in the bottom left corner there is a "mark all" option. You can do that and the unselect what you want to keep.
The other option, if you don't like those red numbers over the mail app is to follow these directions:
settings > notifications center > mail > select the desired mail account if you have more than one and then turn off "badge app icon"
this works for any app that has those (sometimes annoying) red icons. If you don't want that large number of unread emails on your mail app, use this method. If you want to delete them, use the previous suggestion.
Hope this helps!
iPad 3- iOS 7.1.2
iPhone 5S- iOS 7.1.2
iMac 21.5"- late 2013
May 30, 2014 | Tablets & eReaders
Why can't I finish playing on mini golf matchup screen goes black on ipad
The app is crashing. Make sure that you have no other apps open in the background as they drain your iPad's processor speed, and that you have at least 1 or 2 GB open in storage as that will help as well. If you haven't in a while shut the iPad all the way off for a minute and then turn it back on. Sometimes that will also help to clean it up and perform better. Make sure your operating system is completely up to date as well. If that doesn't help then the app is just too much for your iPad to run properly.
May 13, 2014 | Apple iPad 32 GB WiFi Tablet PC
How to delete from ipad
core apps of iOS which cannot be deleted!
1) Airdrop
2) Apple Store
3) calendar
4) camera
5) clock
6) contacts
7) facebook
8) game center
9) iBooks
10) iTunes
11) mail
12) maps
13) messages
14) music
15) newsstand
16) notes
17) photo booth
18) photos
19) reminders
20) safari
21) settings
22) siri
23) tips
24) touch ID
25) videos
- here are 2 different ways to delete an App:
1) t's easy to delete apps from the iPhone or iPad. Simply tap and hold on any icon for about 2 seconds - see them to start to wiggle and tap the X button in the left corner. that's it.
2) For devices running iOS 5 and later, there is also another way to do this is hidden in the Settings app, in the General tab, under: usage.
Feb 08, 2014 | Tablets & eReaders
My Bluetooth seems paired but no sound
It helps to state what iOS you are running for these kinds of problems. Depending on what app you are trying to use, you sometimes have to literally tell the iPad to choose your earpiece for sound for that particular app. Also be sure your bluetooth volume is up. This is independent of your main volume and can be adjusted only when connected. Simply use the volume adjustment on the side of the iPad. Some earpieces have their own volume control as well. Be sure to tap that up a few times as well.
Jan 27, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Can not facetime
***Try this FIRST*** sometimes the icloud account may fail to connect to the Internet you can fix this by simply restarting your phone
a good way to check if you have facetime is to go to the settiings app and go to facetime panel there.
see if you are signed in and see how you can be reached (i have set up my mobile number and 2 mails where i can be reached by facetime)
in order for facetime to work the other person you are trying to contact must have facetime enabled (i.e. have iphone 4 or higher, have an icloud account ) a good way to test is to see if the person can be contacted through imessage
and make sure the person's phone number is listed as iphone in your contacts app
sometimes the iclod account may fail to connect to the Internet you can fix this by simply restart ing your phone
Dec 22, 2013 | Apple iPad Mini
IPad won't allow me to change Facebook users? We have two users and now can't switch between the two.
If you are having difficulties on the mobile site I would suggest downloading the free Facebook App for iPad from the iTunes store. You can touch the same 3 line symbol to open a side bar and Logout is at the bottom.
Unfortunately, if you are on the mobile site the only way to switch to the Desktop site is to open the left side bar.
If you are using the app, try deleting it, then reinstalling. You may also want to see if there is an update available which may fix it as well. If all else fails, use safari to try to use the mobile website.
Best of Luck!
Jul 10, 2013 | Apple iPad 2 Wifi 16GB
Tablets & eReaders Logo
67 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
