Question about Refrigerators
PSS26SGRB why is ice black? - Refrigerators
Black flakes
Dose the whole cube have a black tint to it? or dose it have black flakes in it? If all the ice has a solid black tent to it then check your water filter most all filters has charcoal in them when you change one out and apply water to them you need to dump the ice until you get clear ice. Now if it is just black flakes in ice than you need to clean the ice machine with scotsman cleaner nickle safe and scotsman sanitizer follow manufacturers instructions.
Aug 30, 2013 | Scotsman Kitchen Appliances - Others
Black ice
My advice throw the dirty ice away then monitor. It could be residue from old filter or even new. This happens sometimes and usually clears it self.
Apr 19, 2013 | U-Line ULine Origins Series Ice Maker 25lb...
PSS26SGRB ice dispenser and controls not working
Check that all your plugs that fit on the replacement board are snug. If that does not help I would send the board back to the dealer. I really don't think it would be a good idea to wait about a return because it may be a defective board they sent you. I will place the service manual HERE If you would like to test the new board for low voltage test points to see if the external temperature controls are getting power click HERE I will be here when you are ready so please ask questions Thanks John Tripp
Jan 30, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
G.E. profile mod. # PSS26SGRB SS not cooling
Check to see if the compressor is running. If it is not running take note if the fan beside it is running. If it is the main board is most likely bad. Remove the main board and check for burnt solder joints. If you are familiar with soldering you can fix any bad solder joints and your refrigerator may go back to work. This page will help http://www.appliance-repair-it.com/GErefrigeratorrepair.html
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
PSS26SGRB SS freezer not getting cold and temp lights not working
Dear Sir,
Since last two days our refrigerator(Sansung Bio fresh) has not been working. So make a solution immediatlly.
Our add is -
30,31 Ganga vihar society,Pioneer fitness club, Near Harinagar, Rajesh tower road, Gotri Road, Baroda- 3900 21.
Ph.0265- 2399014
email. dakshamm@yahoo.co.in
Thanking You,
Daksh Mistry
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No Water to Ice Dispenser
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker. Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Black on ice
i would inspect the "black dots " a little closer, the ice maker mould itself is painted with black teflon fininsh if indeed the mould paint is peeling id empty that ice and replace the icemaker
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSS26SGRB SS small water seep
under the trim there are 2 openings on on each side insert a flat head screw driver and twist so it will unlock and then it will be off hopefully you dont have to remove all insternal parts inside dispencer i will try one tomorrow at work and let you know
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
