Question about Garden
How do I tighten the deck belt on my lawn chief 440?
3 Suggested Answers
  • 10865 Answers
SOURCE: how to put deck back on
http://ipl.ordertree.com/ipl/189/440N_440AN.pdf here is the schematic that may assist you. This product is from true value hardware store so if all else fails, go to any true value and speak directly with their technician
Posted on Apr 27, 2009
  • 6468 Answers
SOURCE: Lawn chief 440 j. I either need to purchase a new
try and look it up on sears parts online and cross reference the part number
Posted on Mar 29, 2012
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How you tighten belt on sears craftsmanriding lawn mowermodel917270641
Which belt are you talking about? the drive belt or the blade belt, Usually there is NO adjustment for belt tightening unless you have a tension pulley is stuck and not doing its job
Jun 21, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
Lawn chief mower throws belt
does the belt feel tight when its on? i would look for belt alignment warn blade mandrels or rotted out deck and the belt tension pulls them apart
Apr 07, 2012 | Garden
Replaced deck belt and it keeps coming off,whats wrong?
The belt tensioners on top of the deck need adjusted, or you make have to adjust the pulleys to tighten the belt. Sometimes if you have the deck lowered to low to the ground, uneven terain can cause that. If you have everything adjusted correctly, simply raise the deck another notch and mow.
Aug 09, 2010 | Yard Machines 155 Torque Briggs Stratton...
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Looking for a partslist for a 1996 Lawnchief its
Hi and welcome to FixYa. I am Kelly.
From what I have found in the books you have a 1996 MTD Lawn Chief. There are 11 different models!
The MTD part number is 745-0433 It does not list width.
However a net search of the part number comes up with 69-9/32" length and found a list price for $33.99 + shipping.
It also states the belt was replaced by this PN:
954-0329A
http://www.mfgsupply.com/m/c/12-6842.html
$25.89 + Shipping
The belt is common to most all 38" side discharge decks.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Garden
Need a belt diagram for a lawn chief 400 need routing diagram
go to partstree.com.put your make and model # in.then click deck assembly.hope this helps.
Jul 11, 2009 | Garden
How to put deck back on
Apr 27, 2009 | Garden
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
