Have a UN55f6350 LCD TV and overall picture flickers bright and dim on all inputs and smart TV Apps. Any suggestions ?
techman
  • 3130 Answers
SOURCE: tv still dim after adjusting
sounds like you may have gotten a pwer surge and blew out the regulator in the set. If you know how to trouble shoot regulator curcuitds then it could be as simple as the str type regulator. If you dont then open the set and see what module the set has it would start with a 9-something as it should be inside the back cover and then contact http://www.tristatemodule.com and see what they charge to repair the entire pcb or the exchange of the module. As Zenith sets are made to be repaired in house by quilifyed repair stations IN hOUSE. Good luck to ya.
Posted on Apr 27, 2006
ginko
  • 19396 Answers
SOURCE: Sony LCD TV has Dark Picture
the problem is not the lamp.
This model has a set of two backlight lamps, and it is practically impossible that both lamps go faulty at the same time.
When the backlight lap in an LCD TV goes off in this way, the faulty part is always the backlight inverter, that is the high voltage board powering the lamp.
In your case you have to get the TV inverter booard replaced.
Posted on May 30, 2009
Geekman
  • 32281 Answers
SOURCE: Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 25, 2009
  • 197 Answers
SOURCE: sony bravia 46 lcd The picture dims and
set has a light sensor. go in menu and turn light sensor off
Posted on Jul 02, 2009
  • 336 Answers
SOURCE: Sony KDS-50A2000 - bulb replaced but picture still yellow
Hi,It sounds like a light engine problem Sony is having.Basically the light of the lamp goes through tunnels that have mirrors that direct the lamp to 3 main LCD chips,These 3 LCD chips are blue,green, and red they blend to create the image and colors.When they start to fail you'll get color discoloration like what you are getting.You will need to replace the optical block because unfortunately they don't sell the LCD chips by themselves.GOD BLESS YOU!
Posted on Oct 06, 2009
Screen is black, but still getting audio
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Samsung UN32F5500 32-Inch 1080p 60Hz Slim...
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
Tv dims after turn on
is the auto contrast on? If room is bright it will dim to compensate for brightness.
May 26, 2012 | Panasonic TCP50UT50 Smart Viera 50 Class...
Ln55c650 keeps flashing bright to dim very fast after about 30 minutes of being on if i shut it off for a few minutes it goes away til about 30 minutes the picture never goes away just gets bright and dim...
I had the same issue occur on my ln55c650 (screen flickering, not the actual image but the front lights flashed which was too distracting) and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Jul 22, 2011 | Samsung LN55C650 TV
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 18, 2009 | Toshiba Satellite 4090XDVD Notebook
The left side of my Dell inspiron screen is darker than the right. Changing the brightness only changes the brightness proportionately. any suggestions
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Apr 29, 2009 | Dell Inspiron 1525 Laptop
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
