Question about Dishwashers
Ultime chopper blade and screw cap on the top of shaft mine is cracked it came offf and damaged the blade and cap while running
SOURCE: Blade will not release
Our blade just came apart at the seam just above the blade, so we know what's inside. There is a small v-shaped piece of spring wire that is spread apart from the stem that is mounted to the machine. When the button is depressed (it's on a tiny spring, like a mattress spring, and that's what makes it bouncy), it spreads the v-spring wire and releases it. If you can get the seam apart, it will release the v wire and not damage the machine. Replacement blades are available on-line for $13.95, and whole machines are available on e-bay. Good luck.
Posted on Jan 06, 2008
SOURCE: blade
Ultimate Chopper™
Customer Service Our Live Chat customer service department is operational Monday through Friday between the hours of 6 AM and 5 PM PST. For after hours help, please leave a message, and we will get back to you via email as soon as possible.
search%3fsourceid%3dnavclient%26ie%3dutf-8%26rlz%3d1t4pcta_enus244us247%26q%3dultimate+chopper&text= close window initiate_close.gif Contact us by mail Ultimate Chopper, LLC
P.O. Box 361369
Los Angeles, CA 90036
Contact us by phone (800) 554-6061
_uacct = "UA-3009509-16"; urchinTracker();
Posted on Feb 02, 2008
SOURCE: how do you remove the blender blades from the ultimate chopper?
Press and hold down the center shaft of the blade assembly and lift the blades straight up. You can go here: http://www.ultimatechopper.com/chopper_ul_manual_eng.pdf for a downloadable pdf copy of the user's manual.
Posted on Feb 14, 2009
aborcass
  • 2651 Answers
SOURCE: Whirlpool dishwasher chopper blade
you can replac the chopper as a seperate part, but will quickly clog, and destry ohter parts of the unit if removed. dont take this the wrong way but if you have a garbage disposer already rinse the dishes better to avaid further clogging of chopper
Posted on Mar 31, 2009
SOURCE: BROKEN PART TO ULTIMATE CHOPPER
new blade
Posted on Jun 20, 2010
Where can get replacement plastic cracked around blade on ultimate chopper where can get replacement
talk to an appliance service center to see if they are available
go google to the manufacturer's spares department
Sep 14, 2015 | Ultimate Chopper Food Processors
Tip
Ref: Poor cleaning or noisy pump on Whirlpool or Kenmore dishwasher. April 25,...
A plugged up sump can cause a multitude of problems in a dishwasher, it can make the dishwasher not clean as well as it should, make the cycle run longer, it can create noises and redeposit food.
To clean the sump follow the directions below.
- Remove the lower rack
- Remove the lower wash arm (1) by turning the nut (4) clockwise (right) lift the arm off, there is a bearing (3) (small thin plastic washer) under the arm, be sure not to loose it. Lift the tab on the back of the feed tube cap (2) and swing it to the right and lift up, this may need a bit of pressure to release it.
- Remove the 4 screws (3) from the accumulator (1), lift off the accumulator. Remove 1 screw(7) from the cover (8) this is located down inside of the sump (4) on the left front side. Lift up and remove the cover (8), watch for glass and clean out all the debris from the sump and especially around the the area of the chopper and screen (6) which will be exposed with the cover (8) off. If the screen is blocked with debris that usually means you need a new chopper. it may be broken or loose and not doing its job.
Once clean reassemble and enjoy a dishwasher that cleans the dishes again.
More dishwasher links
flashing_or_blinking_green_clean_light_7
general_dishwasher_cleaning
Hard_water_calcium_white_powder_build_up
on Sep 29, 2010 | Dishwashers
Ultimate chopper/blender is leaking. Where can I get a replacement
probably its the rubber that hold the blade cover to the mug is damage..if you cannot get a rubber then you need to buy new blender.good luck.
Sep 23, 2011 | Ultimate Chopper Food Processor
The housing with 2 blades is cracking. It has not had heavy use just soft items I is a ultimate chopper. How can I get a new replacement.
You cannot buy spare parts. Like many such products promoted on tv home shopping channels it's a poorly made overpriced item with no aftersales care.
Sorry, but your only fix is to replace the chopper with a better one where more than half of the price isn't used to pay for over-the-top adverts.
Jul 28, 2011 | As Seen On TV Ultimate Chopper Food...
I had just finished cheese and couldn't get the
If still interested in a replacement for the Ultimate Chopper - there is a website call TV Time Direct - website: http://www.tvtimedirect.com.
Their phone # is 800.238.7119. On their website, use the Quick Find option (upper right corner) - type in Ultimate Chopper and it will list the replacement listing for this item.
Oct 04, 2009 | Ultimate Chopper Food Processor
How do you remove the blender blades from the ultimate chopper?
Jan 03, 2009 | Ultimate Chopper Food Processor
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Ultimate chopper lid
Here is a phone # for replacement parts that I got from customer service, but I haven't tried it yet on open hours.
Dec 09, 2007 | Ultimate Chopper Food Processor
Blade
Ultimate Chopper™
P.O. Box 361369
Nov 24, 2007 | Ultimate Chopper Food Processor
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
Owen Barnes
