Question about Dishwashers
My integrated HLSI 550GT dishwasher door won't fully open to 90 degrees , it is not catching on the plinth & we can't see why it won't open fully, any suggestions????
  • 9 Answers
SOURCE: Dishwasher door not catching
that is the spring thats gone and will not lock the jaws you need to replace the lock on the door normaly about£5.00
Posted on Dec 06, 2007
SOURCE: Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Posted on Mar 16, 2008
SOURCE: neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Posted on May 05, 2008
SOURCE: adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Posted on Aug 17, 2008
  • 10865 Answers
SOURCE: Neff dishwasher door catch not corking, door does not close ?
look carefully at the catch and the latch as almost all can be adjusted with just a screw driver.
Posted on May 31, 2009
Ge dishwasher leaking
Check the door seal carefully for accumulated food debris or grease build up. If its a built in model with a wooden door panel, make sure the door gasket closes fully before the wooden panel makes contact with the cabinet - sometimes poor adjustment here prevent s the door gasket from closing fully. Water or rinse aid leaks from the machine must be treated seriously and mended, as they pose a significant fire risk. Rinse aid tends to dissolve electrical wiring insulation!
You may need to adjust the door catch on integrated machines to ensure the door closes correctly.
Feb 03, 2018 | GE Dishwashers
Hi, this is an integrated dishwasher and with the kitchen door attached won't open fully.
Maria, adding the door to the front of machine has increased over all thickness to what was existing, washer was not designed for the extra thickness and will catch on lower part of washer.
You may have a few choices, shorten added door panel, taper bottom of panel to allow operation, or remove added panel.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 04, 2016 | Dishwashers
How do I fix a dishwasher
It sounds like you have a broken wire. You might also open up the dishwasher junction box (unplug the dishwasher first), and make sure the wire nuts are tight.
May 16, 2015 | Dishwashers
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
The door on my miele G481 built in dishwasher won't stay open it's really annoying that it keeps popping up when I'm trying to load.
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
May 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
May 07, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Belling integrated dishwasher not working properly
are you sure it is the board at fault, not justv the door catch? (as the door wont open). If the dishwasher believes it has just finished a cycle and the door has not yet been opened it will not let you change the program.
I had this same problem so I hooked an allen key around the back of the white door catch and pulled it into the unlocked position with a pair of pliers. Has worked fine since but every now and then the catch will pop back into the locked position when the door is opened.
Nov 25, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Door won't close
Yes. They are available. often including the microswitch not too expensive.
Oct 31, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Put back smeg oven door
Yeah I was stumped with this for a short time as it isnt imediately obvious.
The bottom of the two brackets has a flip up catch, place these in the upright position and with some force hook the upper bracket into these catches (please ensure you keep your face and hands away from the direction of the spring)
Once you have the two brackets held open offer up the door at exactly 45 degrees (notice the notch on the underside of both lower brackets) locate this notch on the door hinge hole studs.
Once this is done and your certain it is in the correct postion lower the door from 45 degrees to 90 degrees, put some pressure on the door slightly past 90 degrees and carefully fold down the flip up catches that are holding the upper brackets.
Jan 28, 2008 | Smeg SE250XUK Stainless Steel Electric...
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
