Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman motion sensing control console
When i snap in all 4 tabs on the top button of the contron unit, i can not push the button. it appears to be stuck. if i leave the bottom 2 tabs out the button works but it falls off easily. is there a spring in there taht i am missing? i cant find an exploded view of the control unit.
dooropener model 139.53918D
motion detecting control console model 41A6317
The problem is the tolerance between the plastic piece and the cover. when you screw in the top screw it tends to flex the board so it is tight against the black tabs that touch the switch. The board can be too tight toward the front and when the cover is installed it depresses the switches. I removed part of the tab that holds the board in place where the top screw goes in and removed part of the melted plastic that holds the board in place. Also make sure you have nothing behind the board so it can move back and forth.
Posted on Dec 12, 2009
    President:
  • 3,197 Answers
Try calling this number and ask your question. They are the manufacturer and just may help you.
Technical Support Hotline at (800) 528-5880
Posted on Jul 25, 2009
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Button has pushed in dropping into opening behid front panel;To access, must top of washer be removed to allow access to fron wall where button has dis-engaged?
This model usually has two screws hidden under corner trim sections that snap on each end. The best thing to do is grab the top part of the endcap and pull back towards yourself. this will make it come loose and then remove it. Under these endcaps will be two screws...one in each corner , remove these and pull towards you and up the whole console should come up......now, sometimes, there are four screws holding a back cover on...if so, just remove these and you can see everthing there. the start switch just is held in place by a plastic tab thats attached to the switch. The switch has a square shape which you line up into frame and turn switch like 1/4 turn until the locking tab snaps into place...its possible that the switch fell apart and if it did...you will need to replace switch
Bruce Denton
Dec 12, 2010 | Kenmore 84052 Dryer
I have a motion detector console which does turn the lights on the garage door opener when it senses motion, but it fails to turn it off from time to time once I've left the garage. I've replaced the...
The wires going to the wall control are color coded. One of them is white and the other is white with a red stripe. Make sure they are attached to the correct terminals at the motor unit and on the back of the wall control.
Oct 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Dont know how to connect my xbox 360 controller
There are 2 sync buttons. One on the console and one on your controller. Push the one on your console(a small white button on the bottom front of your faceplate) You will see green lights in a circular motion. Then push and hold the small white button on the top of your controller until it also does the circular motion then release. You should then see the controllers and console link and the lights will stop blinking. There you are(connected) I hope this helped
Jan 31, 2010 | Microsoft Xbox 360 Wireless Controller
Craftsman GDO - Remotes not working
I think this is an easier way to program. Press and hold the button on the remote and then press and immediately release the smart/learn button on the rear of the motor unit. Do this for each remote you have.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Jun 28, 2008 | Whirlpool GHW9400 Duet Washer
Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Problems With The Wii Remote Controller
hi yeah i had the same problem with mine i phoned nintendo and they told me to turn the remote on its side and tap it three times on a hard surface this resets the motion sensor on the remote and yes it works,im am now a happy bowler. let me know if it works chez111@hotmail.com i also have number of nintendo if needed
Jan 14, 2008 | Nintendo Wii Console
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
685 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
