How much weight a cubic yard of lime rock - Office Equipment & Supplies
A ton of lime rock how many yards
  • Lime Rock (919) = 1.25 tons (2500 lbs.) per cubic yard so your almost a yard
May 11, 2017 | Cars & Trucks
What weight in pounds is 0.89cub yds
Cubic yards is a measure of volume while pounds is a measure of weight. There is no direct conversion between them because it depends on the density of the substance.
For example, 0.89 cubic yards will weigh a lot more than 0.89 cubic yards of feathers.
Oct 30, 2016 | Office Equipment & Supplies
Need to fill a 132ft long ditch that is 2 ft wide and 18in high with rock. how many yards do I need
We need to convert everything to a common unit, so let's convert the 18 inches into 1.5 feet.
Volume is length times width times height.
v= 132 x 2 x 1.5
v= 396 cubic feet
To convert to cubic yards, imagine a yard cube. It is 3 feet by 3 feet by 3 feet for a total of 27 cubic feet.
v1 = 396 cubic feet/27 cubic feet per yard
v1 = 14 2/3 cubic yards
So 15 cubic yards should do it.
Good luck.
Paul
Apr 27, 2016 | Office Equipment & Supplies
How many yards are in one ton?
One is a measurement of length, the other is a measure of weight.
however, you might be referring to 'Cubic Yards'?
depends upon the rock type and how fine it is, but one reference notes that one cubic foot of gravel typically weighs about 100 pounds.
So 1 ton has 2000/100 or 20 cubic feet of gravel. A cubic yard is 3x3x3 = 27 cubic feet to the cubic yard
Answer is 20/27 or 0.74 cu yard. I'd round that to 3/4 cubic yard.
Jan 09, 2016 | Cars & Trucks
I needs to convert 1,361 cubic yards of 3/4" crushed rock to tons
Using the weight info provided in the link - 1 cubic yard could be about 2,780lbs. Depending on water content, density of and type of stones in the mix - 1 cubic yard could approach a weight as great as 4,000lbs.
Let's assume for easy calculations that an average cubic yard weighs 3,000lbs. (or 3,000lbs/2,000lbs = 1.5 tons).
That means 1,361yds x 1.5tons = 2,041.5 tons.
Lighter average cubic yards as mentioned in the link? Then 2780lbs/2000lbs = 1.39tons/yd. - or -
1361yds x 1.39tons = 1891.9 tons
Heavier average cubic yards as mentioned in the link? Then 4000lbs/2000lbs = 2tons/yd - or -
1361yd x 2tons = 2722 tons.
How Many Tons In 1 Cubic Yard Of 3 4
Oct 15, 2015 | Office Equipment & Supplies
I am lying rock in my back yard so for me buy rock I Need to change feet into cubic feet
60 x 4 x .33 = 79.2 cubic feet. 27 cubic ft = 1cubic yard. 79.3 / 27 = 2.9 cubic yards
Mar 18, 2015 | Office Equipment & Supplies
Convert tons to yards
something wrong with that question:
because "ton" is for WEIGHT
and "yard" is for DISTANCE!
short ton = 2,000 lb (about 907.18kg).
1 yard = 3feet = 36 inch or 0,9144 Meter
Feb 15, 2015 | Miscellaneous
20 YARDS OF DIRTY RIVER ROCK EQUALS HOW MANY TONS
Hello. That's a little tricky. I had 10 yards delivered years ago and I figured that I filled my wheelbarrow about 15 times for each yard. Keep in mind that usually 10 - 12 loads of soil is about 1 cubic yard, but obviously lighter and easier to push. So,...count on about 160 -180 lbs per load times 15 loads per yard equals 2400 - 2700 pounds. Times that, times 20 yards, and you have 48000 - 54000 pounds, or about 24 - 27 tons. Now, you have to think about all that dirt on the rocks which I don't think will add too much weight unless it's being dug out of clay then you might want to add a few hundred pounds per ton.
Sep 17, 2014 | Garden
How many tons are in 941.39 yards
Ton is a unit of mass (or weight), yard is a unit of length. There is no direct conversion between them.
Do you mean 941.39 cubic yards? If so, cubic yards of what? 941.39 cubic yards of water weighs about 720 tons. 941.39 cubic yards of lead weighs about 8160 tons.
Aug 25, 2014 | Cars & Trucks
200 yards to cubic feet than cubic feet to tons for chicken manure that's been composted
You say 200yds do you mean 200 sq yds or cubic yds? There are 9 cubic feet in a square yard 1ft deep and 27 cubic ft in a cubic yard. You will have to know and factor in the weight of 1 cubic ft of manure to get your tonnage. 2,000 lbs in a short ton.
Aug 22, 2014 | Office Equipment & Supplies
44 people viewed this question
k24674
jasbo
jasbo
