Question about John Deere Garden
My john deere sst15 quit steering at all . what could be the problem . it has no vacuum line filters going to the vacuum controls
  • John Deere Master
  • 7,515 Answers
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
John Deere Spin Steer SST15 SST16 SST18 Service Repair Manual
Posted on May 15, 2017
My john deere 4200 hst tractor quit moving,power steering quit,frt loader quit all at once fluid level is ok
hydraulic pump problem
check drive connection to the pump
check input line to the pump has no air leaks and sucking air
Oct 25, 2016 | John Deere Garden
Wiring diagram for a john deere sst18 lawn tractor
Russell if you truly want to figure out this problem you need to look at the wires and ware they connect .And what they connect to then drew your own wiring diagram its not that difficult if you break down and do a few tests with an OHM meter to see what is connected and what happens when you through a switch or run a jumper wire to a ground .
If you think about its not really that complex .
Jun 08, 2016 | John Starter Deere Sst18 Spin Steer Deere...
Why does my steering not working atfer my john deere 400 run awhile
bad check valve going to steering chang hydrostat fluid and filter
Sep 04, 2014 | John Deere Garden
John deere 2640 diesel
Air leak in fuel line/fuel filters etc.
Jul 21, 2014 | Peg Perego John Deere Farm Tractor and...
My John Deere SST18 tractor will not turn left or right once I engage the PTO on the mower deck. As soon as I turn the PTO off, the tractor turns just fine. Any ideas/suggestions that I might try to fix...
Some more details would help. Your tractor has a combined electronic and vacuum controlled steering mechanism. Some people have reported your issue just because of a low voltage issue, and replacing the battery fixed it. In other cases there are two micro controller switches under the fender deck on the right side. These switches should both be able to be depressed and "click" and retract with a healthy solid feel. If not replace the switch. There are also 2 vacuum 'pots' and a vacuum system associated with your steering control. A vacuum leak may also be a culprit (although in my head that might be more constant). Does the steering work in reverse?
Oct 01, 2013 | John Deere Garden
John deere 6520 2005 model, the heater plug light keeps coming on to tell me the fuel filters need changing, even after ive changed them! i tried swapping the sender unit on the glass bowl to no avail, it...
Sounds like low fuel pressure.The filter sensors come on from low pressure which they think are clogged or dirty.Check the injection pump for air or vacuum leaks,even the feed line is suspect.Check the fuel pump and its lines too.
Jan 28, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
I've got a John Deere SST-18 riding mower. I've lost the steering when in forward, but not in reverse. Last time this happened, I had a blown diaphram. This time both the forward and reverse diaphrams are...
GO ON LINE TO JOHN DEERE PARTS YOU CAN DOWN LOAD PARTS DIAGRAMS AND WIRING DIAGRAMS ALSO. CHECK THE PLUGS AN THE WIRING HARNESS AND MAKE SURE THEY ARE CLEAN. WITH A VOLT METER YOU CAN CHECK AND SEE WHAT VOLTAGE YOU ARE GETTING TO THAT RELAY. I DON'T HAVE A DIAGRAM TO LOOK AT BUT IF I CAN FIND ONE ONLINE I'LL LET YOU KNOW. HAVE YOU CHECKED FOR A SECOND RELAY
Sep 14, 2009 | John Deere Air Cleaner Bowl For Tractors
I have a John Deere 116 not getting gas to the filter or carb
It shouldn't have a electric fuel pump. What I would do first is take the gas tank off. Take the fuel line off. Drain the gas tank. blow thru the fuel line.put all back on and fill with gas and try again. I'm guessing it sat for awhile. when gas sits for awhile it gets tarnished.any little bit od debris that was in the gas tank could plug the fuel line. Hope that helps You out.
May 25, 2009 | Garden
Garden Logo
169 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
