Question about Refrigerators
Hi, I'm Trying to determine where water is coming from in drip pan. After removing water I cannot source the leak??
    Top Expert:
  • Refrigerators Master
  • 45,065 Answers
Could be condensate drainage from defrost cycle
Posted on May 12, 2017
Leaking water on floor
remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Kenmore Refrigerators
Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Refrigerators
Water leaking under fridge
a contant runing of water is most likely a leak in the ice maker supply hose , an intermitant drip of water is a drip pan thats full in bottom of fridge (closest to floor ) this water comes from the auto defrost cycle most times this water evaporates away , but as fridge gets older it makes more frost that needs melted hence more water ,sometimes it over comes the pan and runs to floor , a good flashlight and getting down to look underneath usually tells you source of leak
Feb 20, 2015 | Refrigerators
I have a Sub-Zero 550 bottom freezer Ref. It is leaking water all the way back & center beyond the drip pan. I have disabled the ice maker by removing the ice bin and it is still leaking water. I...
There is usually one hose and it could have been moved so its not in the pan any more, you should be able to see it near the pan, from the front with the grill removed, use a coat hanger and hook it back into position, if the pan is over flowing, than that's another problem
Jun 26, 2011 | Sub-Zero Bottom Freezer Refrigerator
PUMP WILL NOT STOP WHEN YOU PUT POWER ON . PUMP STARTS AS SOON AS YOU PUT THE POWER ON TO PICK A WASH PROGRAM EVEN BEFORE THE DOOR HAS BEEN CLOSED.
I have seen this on my unit. There was water in the drip pan under the dishwasher. Water in the drip pan comes from a leak. In my case, the water valve was getting so old that it was letting too much water into the unit when it was trying to fill. This cause the filling station to over flow into the drip pan.
A quick fix - I removed the water from the drip pan under the unit and I was able to turn down on the supply valve in the basement to limit how much water could come in. This allowed the unit to run without overflowing. I will replace the water valve soon.
Other possibilities, the float device used to detect too much water in the drip pan or too much water in the unit is stuck in the too full position. Or the pump out pump is stuck and not moving water.
Dec 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
Drip tray full of water, don't know how to get it out to dump
How to remove drain pan on a kitchenAid side by side with water filter .
Nov 11, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator leaking water
There is normally a small shutoff valve installed in the water line servicing the ice maker; you might shut off the flow of water until you locate the problem.
Most drip pans can be slid out but it would be wise to lower the level with sponges or similar to avoid any more spillage than you already have.
If the 'knob' is centered it is probably the release knob for the grill, behind which is of course the drip pan.
Before damning the ice maker (although they are among the most unreliable devices known to man), I would pull the fridge out and examine the fitting where the water line is attached.
Any lime buildup or green corrosion around the fitting would imply that the leak is external to the cabinet and the leaked water is only accidentally making it to the drip pan.
If you haven't been getting blocks of ice in the cube storage bin, the shutoff valve is apparently working so you may get lucky locating the source of the leak.
Jul 07, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Water leaking from water dispenser
lot of water coming from under the refrijerator
Jan 11, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Fan blows out a smell from underneath fridge could it be leaking gas.
I have the same problem with the odor. I took the back off and discovered the drip pan was full of stagnant dirty water. This place is bacteria heaven. The problem I have now is that i cant seem to find a way to remove the pan without taking the motor out and everything. Any suggestions?
Roman
Jul 02, 2006 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
