Question about Troy Garden
How do you put a shear pin back in a troy bilt 5 hp shreader vac
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Posted on Aug 05, 2009
SOURCE: Troy-Bilt Chipper/Vac 5HP gas leaks out the carburetor
The float may have a hole in it causing it to sink and not seal the needle. Look at the float and check it for holes. You can shake it and listen for gas inside it. if so replace float.
Posted on Sep 07, 2009
  • 6 Answers
SOURCE: Troy-Bilt Chipper Vac Model 47282: Need a part #
Get in touch with frederick7153@comcast.net or 651-786-4277 he has parts new and used. Also does bag repairs
Posted on Oct 29, 2009
  • 152 Answers
SOURCE: troy bilt mower 6.75 hp smoking too much oil...
Check oil level, it could be just excess oil. Also check air filter, it may need cleaning/replacing. Depending on how old the nower is, it could be broken rings in the engine, in that case... time for a new mower. hope this helps!
Posted on May 25, 2010
Dusterz
  • 46 Answers
SOURCE: Troy bilt mower ran fine then died and now it wont
Remove the air filter and set aside.
Take a can of carburetor cleaner and spray the inside of the carburetor.
Let it set for a moment and then try starting the engine. It should run a few seconds. Repeat. When it starts squirt a small shot of cleaner in the carburetor to keep it running. That should remove the varnish the gas leaves as it evaporates over the winter.
If it still won't keep running then there is trash in the float bowl plugging the needle valve seat and the jets.
1) Turn off the gas or remove the gas line and plug it with a small screw or stick to keep it from leaking out of the gas tank.
2) Look on the bottom of the bowl for a nut .
3) Remove the nut and drop the float bowl.
4) Carefully remove the pin holding the float and needle valve assembly.
5) Take the carburetor cleaner with the straw it comes with and spray every hole in the carburetor to clean the jets . (up through the needle valve seat, down top of the carburetor , see a hole, spray it with the cleaner.)
6) Clean the float bowl.
7) Reassemble and make sure the gas isn't leaking and try to start it again.
Posted on Jun 06, 2010
2014 15.5 hp Troy Bilt. Why won't it go forward or in reverse?
Check and see if you have broken or lost a shear pin in one of your pulleys or your wheel drive. Also check your belts and see if they are all working right. One could be broken . Don't get into the transmission before checking these things out.
Jun 08, 2015 | Troy Garden
Briggs 7.5 no compression ?
Broken connecting rod or seized exhaust valve.
Aug 02, 2014 | Troy-Bilt Troy Bilt Chipper Shreader Chute...
I need a parts and owners manuel for a Super Tomahak Wood chipper made by Garden Way Mfg. Co. where do I go to get one?
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.brentchalmers.com/
I note your looking for the Super Tomahawk. If you can come up with a model number I think I can find your parts manual for sure. (or at least an on-line parts list.) Also.... If you can come up with an engine number like OH120 or L90 off of the engine I can find you a manual for the engine also.
This is the list of Manuals available there:
  • 1983 W-W Grinder Inc. Manual and Parts List Super Tomahawk 5-8-2G/C and Tomahawk 5-8-2G/M Chipper/Shredder (40 Pages)
  • 1989 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1989 Troy-Bilt Technical Manual 4HP, 5HP, & 8HP Models Tomahawk Chipper/Shredder (12 Pages)
  • 1991 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1991 Troy-Bilt Knife Kit number 1772231 (1 Page)
  • 1992 Troy-Bilt 5HP Model Service Kit (Part Nos. 1901153 and 1901804) For Chipper/Vac (1 Page)
  • 1992 Troy-Bilt Owner/Operator Manual 47260, 47261, 47271, 47272 Chipper/Vac (60 Pages)
  • 1993 Troy-Bilt Sales Brochure Chipper/Vac (4 Pages)
  • 1993 Troy-Bilt Owner/Operator Manual 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (44 Pages)
  • 1993 Troy-Bilt Parts Catalog 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (16 Pages)
  • 1994 Troy-Bilt PTO Chipper/Shredder Owners Dog Clutch Kit 1902404 (1 Page)
  • Hopefully your model is one of the above.
    Here is link to the Parts manuals:
    http://www.partsandservice.com/html/TroyBilt/cs/
    There are 90 parts manuals there.
    Again with a good model and engine number I can probably come up with your exact manuals.
    Thanks for chosing FixYa,
    Kelly
    Oct 20, 2010 | Troy-Bilt Chipper Shredder
    Have a Troy Bilt chipper/shreader model 47285. I
    Taked the broken belt to the auto parts store for a replacement.
    Jun 06, 2010 | Troy-Bilt ChipperShredder
    Have Troy Bilt 47279. Need Vacuum Snout.
    i NEED A REPLACEMENT VACUUM SNOUT FOR A 1990 TROY BILT CHIPPER-VAC. THERE IS NO MODEL NUMBER FOR THAT YEAR, ONLY DESIGNATED AS "MODEL 5 HP".
    Nov 06, 2009 | Troy Bilt Walk Behind...
    Not getting spark
    I would check that I didn't have a key sheared off in the flywheel, that the start/stop switch isn't faulty, and that there is no missing or weak flywheel magnet. Hope this helped and best wishes.
    Jul 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
    5 hp briggs & stratton on a chipper/shreader
    if the starter rope fails to retract, then you need to either fix a broken spring, or put a new one in. You'll have to take the engine cover off, and you'll be able to see how to take apart the retractor assembly. Often times, just the end of the spring will break off, and if you have a grinder, you can grind the correct shape in it again, and reinstall it as is.
    Jun 07, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
    How do i put a troy-bilt tiller 3 hp.into free
    Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
    5 HP troy bilt chipper sherdder will not rev up under load
    Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
    Mar 18, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
    Garden Logo
    41 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Are you a Troy Garden Expert? Answer questions, earn points and help others
