Question about Cameras
My camera says sd card not ready? - Cameras
  • Cameras Master
  • 5,067 Answers
Has it ever lied to you before ? If not, then it is probably telling the truth
Posted on May 11, 2017
I need an on line manual on how to use my vivitar xx14v2 camera.
You need to go through Setup and find the setting for Format SD Card.
Here are all the Vivitar manuals
line manual on how to use my vivitar xx14v2 Google Search
Dec 29, 2016 | Vivitar Cameras
What kind of sd card goes into my jazz DV140 camera
SD cards should be available at just about any department, electronics, or office-supply store. The brand doesn't matter, though I'd stick with the major brands. Make sure you get an SD card and not an SDHC card.
Apr 29, 2013 | Jazz Dv140 5mp Digital Camcorder Color Lcd...
Memory card says full when i put new sd 2gb card in card won't work on my kodak easyshare cw330 camera
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it.
After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
Dec 30, 2010 | Kodak EASYSHARE CW330 Digital Camera
Formated sd card in laptop now card wont work in camera
once you format the sd card, the computer changes the management and sytem files and makes the sd card ready for use with the computer. so you should be getting an format error.it's recommended that you format the recording media using the device you intend to use it with.i this case, since your using a camera, format the sd card using the camera.check camera instruction manual for additional info where to pull up format option in the menu settings.hope this info helps.tnx:)
Apr 29, 2010 | Cameras
CAN I USE ANY SD CARD FOR MY HP A444 CAMERA..I'M JUST A BEGINNER! ALSO DO I JUST INSERT IT.. AND IT'S READY FOR USE? THANKS..
Yes, any SD card will work. I can't find any documentation as to whether an SDHC card will work. These are high capacity cards but SD cards will work for sure up to 2GB. Check your manual to be sure to insert it properly. You will have to format the card in the camera before use. Just insert the card, turn the camera on, go into the menu and find "format" and follow the on-screen instructions.
Apr 28, 2010 | HP Photosmart A444 Camera and Printer Dock...
Memory card error.
SanDisk is a manufacturer of memory cards. SD card means 'Secure Digital'. There are many types of memory cards, SD being the most popular. You should be able to format your memory card in-camera. Insert your memory card into your camera, making sure that the little switch on the side of the card is in NOT in the 'locked' position. Then go into your camera menu and select 'format memory card'. After that you should be ready to take pictures...
Jan 29, 2010 | Canon PowerShot SX 200 IS Digital Camera
Won't read memory card
This usually indicates that you are trying to use 'newer' SDHC High Capacity cards of 4GB or more. Older and cheaper units like this Vivicam 5024 unfortunately may be limited to 2Gb 'standard' SD cards.
Hope it helps: let me know what cards you are trying to use.
Jan 16, 2010 | Vivitar ViviCam 5024 Digital Camera
Allows only 2 photos without a SD card?
almost all camera should have a sd card
find a sd card somewhere and try that
there should be a menu on there to change lan.
I hope this works
Feb 05, 2009 | Polaroid i1035 Digital Camera
Cameras Logo
93 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
