Question about Pioneer Televison & Video
I have a pdp503 mxe pioneer monitor it turns on lets me into menu lets me scroll down but not left & right an thats the same for buttons on monitor & remote can you advise me of problem
SOURCE: How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Posted on Feb 15, 2009
SOURCE: Mighty Mouse won't scroll down
I have had the same problem on occasion.  I found that if I turn the mouse over and tickle it...  It works!  Only kidding...
Turn the mouse over, push down hard so the ball is depressed, and move it vigorously in all directions.  That usually dislodges whatever is trapped inside.
Posted on Mar 06, 2009
Crankstart
  • 696 Answers
SOURCE: Automatic scroll does not work on touchpad unless you hold down the left click button
This can be set to scroll for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Virtual Scrolling"
Check the box beside Vertical Scrollong and then click OK on this window and the mouse window.
Close the control panel and you're on your way.
I hope this helps Fixya,
Chris
Posted on May 19, 2009
SOURCE: My scroll ball won't allow me to scroll DOWN; I
pop the silver ring off from around the ball and remove the ball assembly. Be careful cause the ring only has connections on three sides and you must start on the side without the "pins". just keep messing with it and it will come out. then clean the rollers up and make sure the flap connector on the bottom is clean and intact. That should do ya for now and should hold you for several weeks
pls rate this fix
Posted on Oct 05, 2009
SOURCE: Philips PC7225 hotel TV - can't access the menu to reprogram it.
0621 is the code- I used 2 different universal remotes(one for menu and one for scrolling) and solved my problem- when I got to cable, I selected no and was able to use all the originally unprogrammed channels
Posted on Nov 19, 2009
No live view nikon d90 camera
Push your camera's settings button (next to top button to left of LCD) and, using the left, right, up, down arrow keys, scroll down to the "Custom Setting Menu". Scroll down to "(d)Shooting/Display". Push the right arrow key and scroll down to "( c4)Monitor Off Delay". Push the right arrow key again and you will be able to choose set the delay between 4 seconds and 10 minutes.
Mar 28, 2014 | Nikon Cameras
Tip
How to set/ change time on your Polar F11.
Having trouble setting the time with your Polar F-Series watch, here is simple quick step-by-step guide to follow.
First know your buttons:
upper right - Scroll
lower right - Scroll
center right - choose
lower left - reverse/ back/ stop
upper left - light
#1 - Push the center right button (exercise will appear)
#2 - Push the upper right button (settings will appear) use the upper right or lower right buttons to scroll if neccessary
#3 - Push the center button (a menu will appear)
#4 - choose Watch, use the upper right or lower right buttons to scroll if neccessary
#5 - Push the center button to choose watch, once highlighted
#6 - use the upper right or lower right buttons to scroll through the watch menu
#7 - Choose Time
#8 - Continue to use center button and scroll buttons to choose and set.
Important button to know - the bottom left button is a reverse button. Make a mistake, just tap that button, keep tapping to go all the way back to the main menu.
on Dec 22, 2010 | Polar F11 Heart Rate Monitor
How/ where to find the adjustment for the brughtness - SharpLLT15G4
Normally the brightness can be controlled by one of the little buttons either on the bottom or on the right side of the monitor.
There will be an icon that looks like the sun to indicate which button will control brightness.
It could also be adjusted by pushing the button that brings up the menu. To scroll through the menu, you'd use the up or down (or left and right) buttons that should be located next to the menu button.
Dec 06, 2011 | Sharp LL-T15G4 (Black) 15" LCD Monitor
How do i reset the equalizer of pioneer car cd player?
  • 1Press the "Src/Off" button until the Pioneer CD player turns off.
  • 2
    Press and hold the "Src/Off" button again until the clock displays in the unit screen. In some Pioneer units, hold the "Multi-Control" button until "Clock Set" appears in the display.
  • 3
    Press the "F" (Function) button on the front of the CD player. In some units, press the "Multi-Control" button again to enter the setting mode.
  • 4
    Touch the left or right arrow buttons, or "Multi-Control," to select the segment of the time you want to change (e.g., hour or minute).
  • 5
    Tap the "Up" and "Down" arrow keys, or turn the "Multi-Control" button, to scroll through and select a number for that field. For example, if changing the hour to "2," scroll up or down until you get to the two. Use the right arrow to scroll over to the minute segment of the display. Use the "Up" and "Down" arrow keys to select the numbers that make up the appropriate number.
  • Oct 01, 2010 | Pioneer Audio Players & Recorders
    I have a pioneer super tuner III D 50 w x 4 and i cant get the AUX input to work please help
    turn the unit off by pressing and holding the off button. The only thing that should be showing then is the time. Then, press and hold the function buttion. This should display the setup menu. Scroll through the menu by pressing the function button (I think). "Aux" should show up and then press up/down or left/right (not sure again). When it says Aux on or yes, turn the unit back on. Press the "source" button until you get to AUX.
    Jan 03, 2010 | Pioneer DEH-P4800MP CD Player
    SVA 17" flat monitor screen color is pink.
    It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
    Apr 10, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
    Pioneer DEH-P4900IB Changing Time and Date
    when the radio is off hold the on the left bottom side for about 3 or 4 seconds and a menu should come on....keep hitting that button till the time comes on. use the up down left right to change it and once ur done just turn on the radio...good lucj
    Aug 28, 2008 | Pioneer DEH-P5900IB CD Player
    Haier LCD TV
    Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
    The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
    1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
    2. Hold the Menu button on the Monitor.
    3. Press the Menu button on the Remote.
    4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
    5. Click the Menu button on the remote.
    6. Click the Left Arrow button on the remote.
    7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
    8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
    9. Push the Power button on the remote, the unit will turn back on.
    10. Click the Menu button on the remote.
    11. Click the Left Arrow button on the remote.
    12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
    13. Highlight Factory and click on the Left Arrow button to select "Off"
    14. Click Menu on the remote.
    15. Click Menu on the remote.
    Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
    Setting clock on my pioneer deh 1400
    the radio must be turned off with the ignition key in the on position... then hold the function key for about 3 seconds if it doesnt have the function key try the audio or source button one of them will bring you to a menu, once in that menu use the func key to scroll though options until you see the clock flashing.. use the up down left right keys to adjust these different options...
    Feb 21, 2008 | Pioneer DEH-1400 CD Player
    Insignia 42 in plasma tv
    cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
    Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
    Televison & Video Logo
    Top Pioneer Televison & Video Experts
    Jaime Hernandez
    Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
