How do I edit the satelite settings - Televison & Video
Can you recording satelite tv with external tv tuner thru s-video cable?
It is possible to record but it recommends more time.
So its helpful that you record via only satelite tv .and then transfer to your pc.
Feb 07, 2012 | Leadtek WinFast A6200 TDH GeForce 6200A...
Missing and out of date drivers
Driver Genius Professional Edition
Oct 16, 2009 | Computers & Internet
Need a toshiba satelite L310 chipset
hello Sir,
You can download drivers from the following link:
http://www.filebuzz.com/findsoftware/Driver_chipset_Toshiba_Satellite_L310/1.html
Aug 12, 2009 | Microsoft Windows Vista Ultimate Edition
Destinator 8 does not aquire satelites
try using the settings and get to satellite then select autosearch It is possible your BAUD and PORT are not set correctly
Aug 01, 2009 | SNK Mio C320 Car GPS Receiver
Tom tom can't find sats signal
Try standing still outside in an open area. If you still don't get a signal it's probably broken but worth trying a reset - reset button generally underneath the unit needs a paperclip to operate it...
Jun 01, 2009 | Tomtom ONE 3rd Edition GPS
Satelite tv through my dvr-550h
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
May 27, 2009 | Pioneer DVR-550HS HDD Recorder
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Receiving satelite
contacted satelite provider, they reset the channel for reception.
Jul 27, 2008 | Mitsubishi CS-35207 35" TV
Won't tune in all channels
Do you mean the channels from the internal tuner which would be channels 22 to 68, or do you mean satelite channels, as I do not know whether this set has a built in satelite receiver? Satelite broadcasters are often changing frequencies or satelites.- Programs come and go!
Oct 20, 2006 | RCA F27440 27" TV
Televison & Video Logo
Top Televison & Video Experts
