Question about Garden
My B&S cord will not pull out. It is not stuck. Help
It is a gas power washer. I took off the pull cord area and it was not stuck. I did not let the cord fling after I pulled the cord to start the machine.
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
If the recoil starter was pulling free after you took it off, Are you sure the engine isn't seized?
Posted on May 11, 2017
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
The pull cord on gas pressure washer wont allow me to pull it as though it is tangled up, But when i removed the housing, it woorks just fine
Sometimes the housing gets bent slightly. A lot of the housings have little taps or prongs that get slightly bent. I would take the housing off make sure it not bent or warp, to make sure there is nothing to block the free flow of then cord flowing. If it pulls fine with housing off, and hangs up when installed it slightly bent. Use small needle nose pliers and gently bend tabs away from area where cord is hanging up.
May 29, 2011 | Briggs & Stratton Prosumer 20324 Gas...
My pressure washers does not start.
Will it start if you pour a small amoum of gas in the carb? If so, carb float needle probably stuck closed.
Jul 06, 2010 | Garden
Pull cord is stuck
Take off your cover to the pull cord, the cord probably just got wrapped around the pulley. If you run into trouble with taking off this cover go to they will walk you through the process off pull cord removal and installation. Good Luck PAL.
Jun 11, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Pull cord stuck on my pressure washer.
Need to remove assembly to find problem.
Mar 10, 2010 | Briggs & Stratton Garden
Pullstart wont pull
sometimes the float in the carb can stick causing the gas to fill the engine, this will prevent the engine from moving and therefore locking the pull cord. check the oil, is there gas in the oil? remove the spark plug and try to pull the cord again. gas may come out of the plug hole . if this is the problem you must change the oil and fix the carb. the other cause could be that the engine is seized. ouch.
I hope this helps
Sep 01, 2009 | Garden
Pull cord won't pull
Check the shaft to see if there is something stuck in there. You can pull the wire shaft out to check. It is wire but looks like a small cable. Good luck...Lee
Aug 27, 2009 | Garden
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
