Question about Cell Phones
Took out battery need to know how to turn phone back on ?
My galaxy s5 won't turn on and the battery is fine
Since you have mentioned about an hardware stress on the phone, the contacts to the display of the phone needs to be checked. Something has broken so that the power to the display or the power button is not working . Have it checked at a phone repair shop mentioning these points
Nov 15, 2016 | Samsung Galaxy Cell Phones
Phone fell in water
If it's at the point where the screen isn't working properly, it's dead. If you have some kind of extended warranty, it may cover it, but there's no real way to bring it back from being water damaged, unfortunately.
Jan 25, 2014 | Samsung Galaxy S GTI9000 Smartphone
I have a Samsung Smooth and it wont turn on past the first loading screen. I took out the battery, waited, and put it back in, several times, and it still wont turn on. What should I do?
What you need to do is to first check if the battery is properly charged. Insert it in another phone and try to power it on, if it turns the phone on and stays on for a while, then it means the battery is alright, but if it does not power it on, then it means the battery is weak and cannot power the phone on beyond the loading screen.
Also you need to test the phone by trying to use another well charged battery in the phone to see if will turn on, if it does turn on, then you know it is the battery that is faulty, but if it does not turn on, then you know the problem is from the phone.
First get the phone flashed before you can commence further repairs on the phone.
Hope this information helped.
Jan 07, 2011 | Samsung Smooth SCH-u350 Cell Phone
Dropped phone in pool. Immediatly dried it out using the rice method( took battery out). 24 hours later put battery back in to see if phone worked and the "flash" light came on. Phone wouldnt turn on.
If you think you can do it taking the whole phone apart worked for someone i know. don't know if it's to late since you powered it up already. Probably worth a shot though.
Jun 21, 2010 | Nokia 6205 Cell Phone
My alcatel one touch is stuck on emergency mode how do i get it off?
I took my batter and sim card out and put battery back in without sim. Next, turned on my phone and then back off; then removed cover and battery again. I then reinstalled the sim, battery, and cover. Turned it back on then it worked. I don't know if this will help in your case, but give it a try.
Feb 11, 2010 | Alcatel One Touch FIRST 20 Cordless Phone
Nokia 5800 won't turn on
"my phone just says NOKIA and its blank white- no matter what you press, no change even though it is fully charged what to do??? pleeeese help "
I had the same problem, I took off the memory card and de sim card, i turned the phone on... and then off... and then I had put back the two cards, and i turned it on again... I worked
Feb 11, 2009 | Nokia 5800 XpressMusic Smartphone
Chocolate phone: frozen
Throw it at a wall lol no I'm just kidding that has happened to me before as well. what i did was take out the battery and leave it out for 5-10mins give or take and then I turned the phone off after putting the battery back in and again taking the battery out for a couple mins after the phone was off and then putting it back in and turning the phone back on and then a bunch of messages were coming through so try that and let me know if it worked for you
Oct 19, 2007 | LG CHOCOLATE VX8500 Cellular Phone
My motorola pebl wont ring but I can play the ringtones manually. Help
Well look on your settings and set your ringing volume to full . check your phone for any settings that may affect your fone ringing . e.g make sure it isnt on silent , Hope i helped
Oct 16, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Lg shine wont turn on
there is a reset button under the battery pack, bottom right-hand corner... i had to use a pin to push it, but then (after reinserting the battery) my phone worked again... not so super happy with this being a problem
Sep 15, 2007 | LG Shine KE970 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
